Top 5 Features list for V3 !
 1-17  …  338-357  358-377  378-397  398-417  418-437  438-442
3628.378 In reply to 3628.377
Michael,
yes again, retopo is the route one as to take now and there are good tools for doing just that out there. You'll probably agree with me that an even better route would be to start directly our work with a SubD program and bypass completely the retopo and or conversion phase. IMHO it would be much more efficient.
Out of curiosity, to your knowledge, is the route from SubD to NURBS somewhat more efficient? I just love using MOI and I'd like for example to be able to add a part made as a mesh from the start, say the "flowers" I made earlier to a mirror frame made in MOI. I already know I could convert the mesh to a heightmap and use ZSurf to get a Nurbs surface. Though it would probably work fine, it's not what I would call an efficient route.
Felix
3628.379 In reply to 3628.378
Hi Felix,
It is, but going in that direction is a relatively new area of tech and it's not very common yet.
But there are 2 tools that can move things in that direction - either the T-Splines plug-in for Rhino (http://www.tsplines.com/) or the Power SubD-NURBS plugin for Modo (http://www.luxology.com/store/Power_SubD-NURBS/) can convert a SubD control cage to smoothed NURBS surfaces.
3628.380 In reply to 3628.379
Michael,
thanks for the info. TSplines seems awsome at first glance, it looks like it brings the best of both WORLD into a single uniform environment. I kind of like that approach. As for Power SubD-Nurbs, it seems more like a mean to translate SubD to Nurbs which is nice as well. Different approach and workflow, I guess it's a question of personal preferences.
Thanks again,
Felix
3628.381
Oh the requests... they just keep on coming!!! ;-)
Have a very happy 4th of July Michael!
I thought I'd enhance my request for the Array by Rotation tool:
Not only could you choose the axis of rotation in 3d space, (while in 3D view too)
but you could also move both the axis point(s) and original object while the dialog is still up and you have yet to hit the "done" button.
This way, one would not have to hit cancel so many times just to reposition the object or axis before rotating.
3628.382 In reply to 3628.20
Hi Michael ...
I would like to see a feature like Sketchup's 'section plane' ... it works line a boolean difference through an object but is not a permanent change and can be easily moved backward and forward fluidly.
It may be fairly simple but I can understand that it might be a hugely complicated bit of programming.
cheers,
eric
3628.383
Workplane is the first thing I need for now
3628.384 In reply to 3628.383
Hi wireframeX,
Check out the Construction Plane tool under View > CPlane, more info here:
http://moi3d.com/2.0/docs/moi_command_reference5.htm#cplane
Does exist a whish list for the V3 like this one ?
http://moi3d.com/wiki/Wishlist
3628.386 In reply to 3628.385
I've just been using this particular thread in the forum as the V3 wishlist.
3628.387 In reply to 3628.384
Wow thanks !!!
Didn't view it ....
3628.388 In reply to 3628.382
I'm also interested to a function similar to "section plane" of SketchUp.
In Rhino a similar function is "clipping plane" and you can define as many clipping planes as you need defining also thickness and colour of the section border with the possibility to have or not a filled cap (if the volume clipped is a solid). In other SW you can define also clipping volumes.
For complex structures, AEC, and assemblies it is a feature really important.
Giovanni
P.S. In sketchup a minus of "section plane" is that you can have only one section plane active (there are workarounds using groups or components but the workflow is not so easy)
3628.389 In reply to 3628.388
<< P.S. In sketchup a minus of "section plane" is that you can have only one section plane active (there are workarounds using groups or components but the workflow is not so easy)
What is difficult in this? ;)
3628.390 In reply to 3628.389
Hi Michael ...
Another one I would like: Styles ... I would like to be able to drag and drop a style into a new location. I know I can do this with the up and down but now that I have added many colors I have many, many styles and it is slow and difficult to add one and not relocate it by alphabetizing (all my colors are now at the bottom of the list and I want to leave them there ... yes, I could rename them to start with z but this is a big job). another assist would be a 'match' option so I could assign these new colors to new names more easily.
cheers
eric
3628.391 In reply to 3628.389
my previous note wasn't clear!
<< P.S. In sketchup a minus of "section plane" is that you can have only one section plane active (there are workarounds using groups or components but the workflow is not so easy)>>
I meant ... you can have only one section plane active at the same time!!
Here an example from Rhino:
3D model with 2 clipping planes INACTIVE:
3D model with clipping plane 1 ACTIVE:
3D model with clipping plane 2 ACTIVE:
3D model with clipping plane 1 and 2 ACTIVE at the same time:
3628.392 In reply to 3628.391
More infos ;)
So yes not excatly the same system :)
Else you have also this Cool plug Zorro2 by Whaat
Of course you must all explode before but you will have any number of Slice sections ;)
EDITED: 21 Sep 2012 by PILOU
3628.393 In reply to 3628.392
It's been quite a while since I played with older versions of Moi3d. It seems some kind of N-sided patch or blend between more than 2 edges has been a want for a while. Is this already in or planned for the v3 beta?
thanks,
Dan
3628.394 In reply to 3628.393
Hi Dan,
These are not in yet but I am definitely trying to target them for v3. I've put in a fair amount of research time into N-sided blend already but it is a finicky area and I do not yet have anything that gives good enough results yet.
3628.395 In reply to 3628.394
Michael.
So if Solids++ doesn't get updated fairly soon, where does this leave things?
It sounds like too big a task for just one person to take on (you) :) and it seems to me that the only other option would appear to be a change of kernel within MoI, or is there some other way to get around this?
Martin (2).
3628.396 In reply to 3628.395
Hi Martin, there is some work currently in progress in this particular area by Solids++, but I'm waiting for bug fixes to it before I'll know whether it's going to work well enough or not.
If it doesn't work well enough then I'll probably work on developing my own. That's not impossible, just quite a bit of work.
3628.397
Hi Michael!
I'm not sure I asked for this request before:
You know how you can control the 'start position' of a Blend or a Loft surface if they are made between closed surface edges.
I run into the need for this often, especially on more complex shapes. And by complex, I mean sometimes a simple bend.
I say to myself: First, wouldn't it be nice to be able to control some point in the middle of a Blend or Loft result surface - on an open surface?
And second, wouldn't it be nice to say, add any amount of control to-and-from points along each edge to tweak the result a little more?
This may already be part of your plans to add things like dual-bulge control and whatnot to Blends.
I think I saw a guy add this extra control to a blend or loft in a Rhino tutorial one time - and I did a double-take and thought "what the heck did he just do?".
This would have good uses... say a particular lumpy area or bump wants to appear but the rest of the Blend looks great... add a little tweaking point-set (like on the closed surface Blends) and thus a little control on the result. :-)
It's okay with me if this goes somewhere deep in the suggestion box. Because I'd still like to see Blending between edges made up of multiple (separate, but joined) surface edges, and that dual or Blend-bulge control thing...
Okay... idea done.
BTW, if I have time, I'd like to make this WIP my next tutorial: :-)
A plastic institution chair, but it's more subtly complex than it looks.
Show messages:  1-17  …  318-337  338-357  358-377  378-397  398-417  418-437  438-442
