Top 5 Features list for V3 !
 1-13  …  314-333  334-353  354-373  374-393  394-413  …  434-442
3628.354 In reply to 3628.353
> for one it's possible for a single object to change
> from an arc to a line for example if you turn on
> control points and delete all interior control points
> leaving only the end ones. Would you then expect
> for that control point deletion to also automatically
> change the style of the curve object from the "arc"
> style to the "line" style?
It's just an initial colour coding it's not expected to change if the entity changes.
I'll give an example where it's used, when curves are extracted or generated from a section of a part model that we need to use to model a mating or complimentary part we would like to see what the curves are made up of, usually the CAM guy's prefer lines and arcs for ease of cutter path generation and smaller data files especially on comlpex shapes, when we see splines generated we try and simplify them into basic joined lines and arcs, so you could imagine if there are 100's of curves generated from a section and there were only two or three splines in there to be simplified you would have to pick on each seperate entity generated to see if it was a line, arc, spline or even an ellipse.
To tell you the truth Michael, I don't think I would use this with MoI because I use MoI for different type of models compared to my everyday software, I just tagged along with Pilou's first post on this topic and didn't really want to stretch the subject this far, thanks for your interest anyway :)
3628.355 In reply to 3628.354
Hi Danny, so from your example that you mention there that definitely sounds like it's being used as a diagnostic tool. I mean if you're using it as a visual method for determining object type, that's a diagnostic or analysis type function...
Why wouldn't a view mode that temporarily changed the display to show colors by object type (like I was describing earlier as a potential thing in the future) give you what is needed for that particular kind of examination?
3628.356 In reply to 3628.355
Yep! that sounds good to me........now waiting for the future :)
3628.357
Please consider an improvement: Auto-panning while making a selection box or holding objects.
You know how when you pan with the mouse and run off the side of the screen and the viewport automatically tracks in that same direction?
CorelDRAW does that whenever you are holding objects or points too, or when you are making a selection box. It just auto-pans the same way MoI does it when you are using the mouse to pan.
Can MoI possibly do this too?
Iit would be helpful if you are trying to box select a small sliver of objects that go off the screen, but you don't want to have to figure out how to select more of the same area after panning.
Or in other words, it would help if MoI would pan as soon as you run out of viewport, especially when you are holding an object or points.
Right now, it just hits the wall and goes thud. And when MoI has teased you with it's groovy auto-pan (while panning) feature, it's kinda a bummer. :-/
... or am I missing something.
Mike
PS... I figured out that when you are moving objects and points, you can simply click and drag with the mouse key for panning and re-adjust.
That still doesn't work when making a selection box.
EDITED: 21 Jun 2012 by MAJIKMIKE
3628.358 In reply to 3628.357
Yep - I'm a Corel Draw user too and auto-pan when you run out of screen would be great for MoI. Especially MoI under WIN8 on a MS Surface :)
Ed
3628.359 In reply to 3628.357
Hi Mike, so there is actually a complication with that which involves the perspective view.
When the perspective view pans, it actually changes what would have been displayed in the now off-screen portion of the selection box. So it makes it kind of awkward to do things that try to work with screen space like selection boxes while allowing panning in perspective.
The auto pan that does currently work is only focused on changing the view and not on simultaneously trying to track some containment in screen coordinates at the same time, so that's why that one is feasible.
Perspective views have this kind of weird non-linear behavior that can complicate some kinds of things like that, like a small movement of perspective view panning can move some things on the screen much more than others - things that are close to your eye point will whiz by and things that are far away move only a small amount on the screen.
re: while holding objects, you mean doing an auto pan for dragging objects? There is a different complication with that, which is that it's currently possible to work in split view and grab an object in the Top view where you can get it more easily but then actually move your mouse over to the Front view and thus move it upwards in elevation. The thing that makes that possible is being able to continue the drag in a different viewport - if dragging did not ever let you leave the viewport you started in and instead panned the view it would then eliminate that function.
3628.360
Hmmm...
I see right now that when you move and object and cross over into another viewport, you find yourself holding the object in a different orientation according to where your cursor is relative to that new viewport.
For an auto-pan to work, while dragging an object, MoI would know to not allow you to cross over into the adjacent viewport, but you would stay in the intended viewport with the panning now taking place.
- just like it does now when you simply hold the mouse button for pan and drag the cursor point through the boundary edge.
It should work in perspective view as well if the pan movement is focused on the relative course dictated by the cursor movement. Where as, with a mouse pan in the opposite direction does this currently.
Since the aspect of the perspective view may change as you pan wherever your cursor is sitting, so would the carried object.
There might need to be some figuring to make it move right if done in a perspective view, but I think it would work fine in the ortho views.
When I think about it, if I'm moving an object (at least in the ortho views) my eyes want to work in that view, when it jumps somewhere else because it crossed over and it is now in a new frame of view... well, I don't know, is bouncing around with the same object from one view to another a common workflow practice? :-/
So, to clarify. (in theory), the object and cursor would stay in the intended view (by which the mouse key was held down) and the viewport would pan in that relative direction - instead of crossing over into the next view and jumping the object somewhere else. - relative to the way the focus remains in the intended viewport when the pan is held down.
3628.361
Okay, I tried something... If you hold down the left mouse key to grab and move an object in perspective view, you can simultaneously hold down the mouse-pan button, go to the opposite side of the screen (with the object now moved to the opposite side of the screen) and pan the view without dropping the object.
Then you can mooooove your object back over and continue.
So I know what I'm thinking about might work, it would just have to know you're going "over there" too without having to click and hold the mouse pan button.
3628.362 In reply to 3628.360
Hi Mike,
Yes, but that "jumping" part can be a useful feature that would then be eliminated with the method that you're describing here.
Currently if you want to grab say this back rectangle here and drag it upwards in elevation, you can grab the rectangle in the Top view here:
Then all in one motion without letting up the mouse you can move into the Front view and be adjusting it in elevation here:
That can be a convenient way to adjust elevation - if things worked the way you are describing this kind of multi-viewport dragging would not be possible anymore.
Basically the split view exists in order to do things generally similar to this like selecting things in the top view and then making adjustments in a different view for elevation.
There is similar functionality in drawing as well - when you draw a curve or a polyline for example you can switch to a different view and place a couple of points in elevation so that you can more easily get a full 3D shape all in one go rather than the drawing being 100% locked to only the first viewport that you clicked the first point in.
It also seems like it would be kind of weird if object dragging was restricted to only be locked to the first view you clicked in but other commands like transforms (move/copy/array/etc) or drawing commands behaved differently and did not lock things or auto pan in the same way.
3628.363 In reply to 3628.361
So basically since MoI is not just 100% focused on 2D drawing but also manipulating things in 3D it can sometimes be hard to exactly replicate 2D workflow like you're asking about in cases where it would cause some degradation in being able to do 3D multi-viewport manipulations.
Aside from dragging, just the basic act of drawing it can be really useful to be able to pick the center point for a circle in one view and then pick the next point in the front view to produce a circle that has its center in some spot that was not easy to pick in the front view but still is oriented flat to the front view because of the second pick going there.
Basically this kind of combination of some picks in one view and further picks in another view can help out in placing things directly in a 3D position in many kinds of situations, the sort of "lock all mouse activity to the first view you clicked in" type mechanism like you are describing would have a side effect of removing all of that current multi view placement abilities.
3628.364
Well... thanks for the explanation. I knew there'd be some good wisdom in the way it was working now.
But at least we have the forum to hammer these ideas out. ;-)
To tell you the truth, the more and more I use MoI, the more I'm preferring the use of the Transform tool set.
As the actions I require become more concise, so - the need for exact placement.
3628.365
It's about quads export again. I know it would be a lot of work to do it in MOI but what about an external program that would do a great job at it in an as automated way as possible. I know about 3D-Coat and TopoGun a little. The later being mostly manual and 3DCoat as an automated means but the result often (if not always) requires additional editing.
Edit: Though I've found quite a lot of research papers on the subject, there seems to be a lot less application implementing these kind of algo.
Felix
EDITED: 25 Jun 2012 by FELIX
3628.366
Not sure why you want quads only export. NGons work fine in most applications, even Blender with the latest release. Unless you want to animate. But why would you character model in Nurbs? You are better of using a polygon modeller for these sort of things
3628.367 In reply to 3628.365
Hi Felix, re: all quads - as far as I know 3D Coat's automated conversion tool would be your best bet. I'm not aware of any other automated processes right now except maybe in Finite Element Analysis software which does analysis of object structures for strength and such. I think some of them have some quad meshing mechanisms in them but that software tends to be extremely expensive.
Getting a nice "all quad" structure involves making good choices about edge flow topology which is something that comes from experience and judgment. It's very difficult to make a totally automated process to do operations that require judgement like that.
Usually like Steve says if you need an "all quad" output you should be creating it that way from the start in a polygon modeler - using MoI for that kind of specific target output is basically not using the right tool for the job at hand.
3628.368
Michael,
I search the net for this but as you say the subject is vast and most research on the subject are still just that. And yes, one of the export cmd of 3D-Coat give pretty good result.
@Steve:
if I was a decent subD modeler I'd do just what you suggested but I'm not. What I'm trying to do for now is I try to create a pretty basic NURBS version of the model in MOI, export it as a dense quads and tris to either Blender or 3D-Coat and I try my best to add the details I want. It's seems to be easier with 3D-Coat, at least for me.
Here is an example.
I should have mentioned these models are intended for CNC.
Felix
3628.369 In reply to 3628.368
Hi Felix - if you're adding details in 3D Coat and you're using its voxel editing mechanism, it doesn't actually make any difference if you have all quads or all triangles - when you import your polygon model into 3D coat for editing using the voxel toolset it gets converted from polygons into a voxel structure at that time, and it does not matter if you have all quads in the original polygon structure or not.
You would only want to go to "all quads" if you were going to be using a sub-d modeling toolset to do further work on the object.
Sub-d smoothing is the thing that particularly likes quad topology - voxelization does not care about it.
3628.370 In reply to 3628.368
Hi Felix, also is that a ZBrush screenshot you're showing there?
You don't need to have all quads to go to zbrush either - you can send a finely diced up mesh and then turn off the "smoothing" modifier inside of Zbrush and it will then not try to use the mesh as a sub-d cage and instead just displace the polygons directly. See here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=804.26
Zbrush has a setting in its subdivide method for whether to use sub-d smoothing during the subdivision or not - you want to turn that off.
Are you really sure that you actually need "all quads" in your output? Can you maybe give some more detailed information about what processes you use on the mesh after you export it from MoI? Because if you want to use those brush based deformation tools on it, that should be possible to use without needing special sub-d oriented "all quad" topology.
Have you possibly seen some tips from people saying that all quads is an absolute necessity for everything? The thing is, that only actually applies to one particular workflow of doing actual sub-d modeling, it does not apply to other situations.
3628.371 In reply to 3628.370
Michael,
I agree with you for both 3D-Coat and ZBrush quads aren't necessary. For Blender though it's another story and I assume it could be the case for many other programs. There are also another kind of program that convert the mesh to a bitmap, these don't need quads either but editing these in the program is somewhat limited, at least those I've tried.
I know it not your problem but I have a hard time learning new stuff and it's the reason I'm using as much as possible programs I've used a long time ago like Blender. It's kind of the bicycle thing, ounce you learn it you don't forget it.
I tried the trial version of ZBrush and I'm useless with it, it's way to different then anything I've used and when it ended I had not made any significant progress with it so I didn't buy it.
The image I provided is a screen capture from 3D-Coat (trial version). This one seems more user friendly to me at least and maybe I'll buy it. The main reasons would be that quads aren't necessary and hopefuly, I'll be able to learn enough to use it for my needs.
Felix
3628.372 In reply to 3628.371
Hi Felix, what particular tools are you using in Blender - you can do things like sculpt mode in Blender on triangle meshes and not only quads as well.
If you're doing sub-d modeling, then yes you need to have a sub-d friendly mesh structure for that and typically that kind of structure just does not get created for you automatically, you will be looking at doing retopology for that.
3628.373 In reply to 3628.367
>Hi Felix, re: all quads - as far as I know 3D Coat's automated conversion tool would be your best bet. I'm not aware of >any other automated processes right now except maybe in Finite Element Analysis software which does analysis of object >structures for strength and such. I think some of them have some quad meshing mechanisms in them but that software >tends to be extremely expensive.
Hi Michael and Felix,
here's a free Windows software which produces quad meshes. Input format is .ply
http://www.it77.de/studienarbeit/index.htm
Show messages:  1-13  …  294-313  314-333  334-353  354-373  374-393  394-413  414-433  434-442
