Top 5 Features list for V3 !
 1-6  …  287-306  307-326  327-346  347-366  367-386  …  427-442
3628.327 In reply to 3628.326
Hi Martin,
> I know that Microsoft had to release patches for XP onwards to handle the
> code better within the their OS's, I just wondered if you needed to tweak
> MoI to make it better suited to AMD cores, or whether it's a
> "guts of the OS" problem ?
It was a "guts of the OS" problem - something to do with adjusting the behavior of the thread scheduler that distributes threads to run on the different available CPUs.
Once the patch is in place for it, it solves the problem at the system level and so individual applications do not need to do anything extra to avoid that particular problem.
3628.328 In reply to 3628.314
Hi BurrMan,
good you mentioned the 'standalone' versions, as I was only drawn towards the Rhino plug-in.
I will try out the 'closed obj forms and will give you some feedback if I could get it to work
on parallels on a mac.
Jan
3628.329 In reply to 3628.314
Hi BurrMan,
the resurf 3d program crashes immediately the moment a *.obj is loaded on my installation.
I tried objects exported from MoI, Cinema 4D and Rhino yet all of them crashed the program.
The surface program instead worked fine and created pretty good results. The pricing though
is way above my need to use it.
3628.330 In reply to 3628.329
Yeah, I had poor results with the obj one too. But I think it just needs more time put in to learn what it is expecting.. It is a very tricky area... The surface one works. You just need to open up your models, so you cant really do "entire heads" and such.
The other thing, is like mentioned in the original postings, the NURBS surfaces created will be "HEAVY", if you are trying to match anything of detail... Pretty much not a workflow to use. The higher end ones I think will produce something more usable though... But if $120 is out of budget, then $15,000 is pretty much not looking too good either!!! lol The other thing with the expensive ones... I think there needs to be lots of time put into the understanding of whats happening and "when, why and how" type stuff.. It's not just pushbutton. So a couple years to get good at it.
3628.331 In reply to 3628.12
There is a great script to toggle between 3 different settings that will cycle between 5 10 and 25 then back to 5 you can change them yourself , for quick detail adjustment. just copy into the command line
script: /* Toggle mesh angle */ var newang, ang = moi.view.meshAngle; if ( ang == 5 ) newang = 10; else if ( ang == 10 ) newang = 25; else newang = 5; moi.view.meshAngle = newang; var sidepane = moi.ui.getUIPanel( 'moi://ui/SidePane.htm' ); var endsection = sidepane.document.getElementById('MiddleBody').nextSibling; if ( endsection.lastChild.id != 'angval' ) endsection.insertAdjacentHTML( 'beforeEnd', '' ); endsection.lastChild.innerText = newang;
cheers
shayne
3628.332
Just wanted to throw my wishlist in also!
1. 64-bit, So I can handle bigger data sets in moi3d, hopefully this means increased in performance also.
2. Separate surfaces base on edge selection(i.e. edgeloop) This will save me lots of time!
3. Lattice deformer: I can see this opening up many possibilities for free form modeling!
4. Improved Network
5. Fillet multiple edges with different edge width
3628.333 In reply to 3628.332
> Lattice deformer (???)
Is that the same thing as "Cage Edit" in Rhino and the NURBS equivilant to Sketchy FreeForm Deformer in SketchUp?
See Here: http://www.rhino3d.com/5/help/commands/cageedit.htm
Man, I would love that tool!!!
Michael, I have a request that just occurred to me. :-/
Would it be possible to add the ability for Circular Array to have a two-point, 3D axis? (just like the Revolve tool lets you do)
Yes, there are three ways to work around this. 1) Rotate your object to a flat plane, go to a view and Circular Array... then rotate back. 2) Change your view-plane axis (that scares me a little still). 3) Use Rotate by axis... but you gotta know your angle.
A circular selection
3628.335 In reply to 3628.333
Hi Mike, yeah right now the main way to do the circular array by 2 points would be to set your construction plane (View > Cplane) to have its z axis running along the axis you want to use. Then when you're done it's easier to reset the cplane (right click on View > Cplane) than it is to relocate objects around.
It could still be a possible feature to add in an axis to the circular array command, but do you need some tips for working with the construction plane right now? Would you like to start up a new topic with an example file that has an axis line in it and an object you want to array so I could show you some steps for setting up the cplane?
But basically if you draw in a line where you want the array axis to go, if you then place the cplane onto the start point of the line, it will automatically orient its z axis to point along the line's direction (unless you turned off "Align to objects") so you don't have to do any other fancy repositioning after the initial placement, you would just right-click to accept the default orientation and then your drawing plane will be set to the plane you need. Then when you're done with the array right click on View > Cplane to reset it back to the default world axes.
3628.336 In reply to 3628.335
Thanks Michael! Yes, I'll do that...
Oh! I can Blend and Loft a cat and dog together, but these "orienteering" tools to me, are like that last can of food in a famine that just happens to be sardines! (you're so hungry... but yuk? :-/ )
I wouldn't mind a two-point (3D-space) axis option in the future for Circular Array, does works great for Revolve. :-)
3628.337 In reply to 3628.334
>>A circular selection <<
2nd that. :-)
Peace,
Rich_Art. ;-)
3628.338
64 Bit support! Sure there are ways to reduce (for example) exporting of heavy models, but using the full 16 Gigs on my system would surely help to avoid the ever-occuring "Insufficient memory" error, or not? Not really sure of all the actual pros/cons of a 64-Bit compared to a 32-Bit. But is that really a question these days.? 64-Bit is eventually the way it will have to go anyway. Or is there a reason to hold out?
3628.339 In reply to 3628.338
Hi Tree,
The main reason is just the amount of work required on my part - producing a 64-bit version would be a major undertaking, I would need to switch to a different compiler, update all libraries that MoI uses and deal with changes and incompatibilities from that, and then also manage more versions of MoI since I don't think I can drop the 32-bit version right now since there are still a lot of users on somewhat older 32-bit machines.
The amount of work involved is enough that it's unlikely to happen anytime too soon - if I were to dig into it, it would require a lot of time focused only on that which would displace quite a large number of other features.
3628.340 In reply to 3628.333
@ Magic, yup that is a lattice deformer - Ideally it should work on Solid too (if that's possible)
3628.341 In reply to 3628.340
Yes it should, considering that the cage control points only represent a matrix of spatial relationships.
All of the control points, and other surface-related coordinated would simple conform to the manipulation of the cage space. (??)
The cage would be made of a X by Y by Z lattice of control points, meaning that you could manipulate the cage points lying within the interior arrangement of the cage and allow for warping of your objects throughout.
3628.342 In reply to 3628.339
Understandable. Although that seems to be just postponing the inevitable doesn't it? As the versions of Moi get "heavier" it will become more difficult I suppose. Just something that I've been seeing often lately with the newest v3 Beta Build while trying to export some heavy models with the "Insufficient memory" error coming up often. Or maybe this is related to the Beta itself? I don't recall having problems with exporting in the past, but maybe I just hadn't been working with heavier models. Moi is still my go to app for converting surface models to polys, but I also don't imagine that the models will get any "lighter" in the future.
3628.343 In reply to 3628.341
Cage editing = "Soft selection" for MoI's points.
3628.344 In reply to 3628.342
Hi Tree,
Yes, but it's not like that's unusual at all - postponing things that require a lot of work is a normal part of the software development process, particularly when working with very limited resources.
Not as far as I am aware of.
Yeah it's probably that.
You should be able to avoid the problem by selecting just some portion of your objects (just half of them is a good thing to try at first), and then using File > Export to write those out. Export is short for "Export selected" and it writes only the selected objects out rather than everything all at once. Then after you've exported one half invert the selection and export the other half to a different file, then in your rendering program import both of those files and then you should have it all transferred over.
MoI is really more primarily focused on being a modeling tool where you create stuff in, it's somewhat more of a side effect that it happens to be good at converting existing CAD assemblies to polygons as well.
I think it will be possible in v3 for me to tune a couple of things up in some of the intermediate processing stages that will help to reduce memory consumption somewhat though. There are also other feature areas like instancing that can actually help out a lot more which I would probably be working on before trying to tackle 64-bit.
Does it possible to have the generator's curves in a different color than default color?
3628.346 In reply to 3628.345
By default colors of objects are controlled by what style they are assigned to, so if you want curves to be a particular color assign them the style you want.
Show messages:  1-6  …  267-286  287-306  307-326  327-346  347-366  367-386  387-406  …  427-442
