Top 5 Features list for V3 !
 1-15  …  256-275  276-295  296-315  316-335  336-355  …  436-442
3628.296 In reply to 3628.295
looks promising as Ferrari seems to work even in between two closed profile curves to which
I could not manage to talk 'Soap Skin & Bubble' into so far...
Here is a direct link to download this plug-in in V 1.1 without the need of registration:
http://modelisation.nancy.archi.fr/rld/download.php?file=FerrariSketchV1.1.zip
Unfortunately it runs on Windows only, so for the Mac users among us it looks like another
installation on 'Parallels' to get a try out.
Thanks for this information!
Jan
3628.297 In reply to 3628.295
@Pilou
Unfortunately the Ferrari plugin as well as sketchup did not work stable for me
on more complex shapes on a parallels windows emulation on MacOS Lion.
Simple shapes and reduced calculation precision and grid resolution works fine
and is really nice to play arround with.
I wonder if there are more stable solutions of such bubble skin tools available,
maybe as a stand alond program with good export options...
Jan
3628.298 In reply to 3628.293
Hi Jan - re: minimal surface,
> The plug-in itself seems to work with quadrangles, at least visually. The triangulation seen
> in the render happened - also visually - after exporting the file.
From what you showed there it does seem to use some amount of quads but not 100% only quads - look near the boundaries of the surface and you can see a lot of them are sliced off, those ones are not quads but instead n-gons.
So you don't have a totally restricted "all quad" topology there - because of that there isn't really an automatic way to transfer from a generalized polygon mesh like that to the totally uniform MxN grid of points that a NURBS surface requires for its control polygon net.
> Maybe I can find a way to somehow re-model the surface back to MoI
> to go further from there.
If you can convert it to OBJ format, you could then use the OBJ to 3DM wireframe converter here:
http://moi3d.com/resources#Obj23dmWireframe_converter
That will convert the edges of that polygon mesh data into lines in a 3DM file, and then that 3DM file can be loaded into MoI, and you'll then have the wireframe of that model which you could use to as a snapping guide when drawing some new curves.
But just in general polygon mesh geometry like you have generated there is a pretty different form of data than NURBS geometry.
Polygon mesh data is made up of a lot of little facet pieces. NURBS geometry is made up of larger smooth spline surfaces.
It is possible to convert a broad smooth NURBS surface into polygons by dicing the surface up into little flat pieces - MoI will do that for you if you export to a polygon mesh format like OBJ, LWO, STL, SKP, ... Think of this step as similar to how you can take apples and smash them up into little bits to make applesauce.
But if you are starting with already diced up data (the faceted polygon mesh type data) and want to convert it back into big NURBS surfaces, that's basically the equivalent of wanting to start with applesauce and trying to reconstruct full apples back from the smashed up applesauce - a difficult task...
3628.299
Back to the golden ratio, why the golden rectangle cant be a default snap? I dont think it would be confusing. The cline golden snap would be very useful too!
3628.300 In reply to 3628.299
Hi ed,
Check out here for an answer:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.285
It could become one if it gets asked about frequently enough. So far it's only been requested or mentioned quite rarely, and things that are only needed rarely by a small number of people are not great to have as defaults.
3628.301 In reply to 3628.298
your visualized example now got me hungry for hash browns... ;)
I understand your point in those irreversible restrictions in between the NURBS and polygon worlds,
even though I would go to freeze back the sauce in its original apple shape in this world... ;)
By searching the internet on this topic so far I could only find the NURBS -> Polygon direction and not
the other way around.
Thank you for the link to the converter which I will try out on those bubble skin surfaces from sketchup
for remodelling in MoI.
Jan
3628.302 In reply to 3628.301
Hi Jan,
I'm not sure it would really be quite the same as a regular apple anymore, especially when you tried to bite into it! :)
> NURBS -> Polygon direction and not the other way around.
There are actually some pretty complex tools to do it used for reverse engineering, but they're usually very specialized and expensive.
3628.303 In reply to 3628.301
Hi Lejan,
You can look at this website here:
http://www.resurf3d.com/
They have a couple standalone applications that do what you are describing.. The mesh to single nurbs one will fit to an "open mesh" (A sheet if you will) not a closed volume. it works off of stl's.
The obj mesh to solid, will work on closed volumes, but is only approxamating what it works on...
The expensive ones michael mentions will do much better jobs, but again, EXPENSIVE.
Also, you can try these demos for a few days... What you will find, is a nurbs surface fit to some organic shape, at any type of tolerance, will be an Extremly heavy surface created... And then, "What do you want to do with it in MoI?" A very heavy, organically shaped NURBS surface may become "unusable" in any type of situation...
You can check those out to see results, but the higher end ones may really be needed to presnt anything that suits what you want.. Maybe the heavy stuff will be good for what your looking for though...
Burr
3628.304
Minimal Surface - by maximal effort ... ;)
A small guidline for a sailing trip on minmal surfaces in MoI...
A basic outline of half of a boat hull sketched freely in MoI
Exported from MoI via *.skp and imported into SketchUp
Within Sketchup a plug-in called 'Soap Skin & Bubble' was set to 50x50 resolution to generate a first auto-mesh
By default the plug-in then calculates a minimal surface connected to the intitial outline of the boat profile as if this skin was a
soap bubble
To get a bit more space within the final boat the plug-in was run again with an imaginative inner pressure set to a value of '30'
From there the was a bit tricky to get the final mesh of this minimal surface back into MoI and may vary on your own software.
In this example Sketchup exportes in Collada *.dae into Cinema 4D which exported in Wavefront *.obj into Obj23dmWireframe
wich finally converted the mesh back into MoI's *.3dm format.
Back in MoI the mesh was manually 'cleaned' to get a better view and less snap option for the 'Through points' curve tool
Any other vertical contour curve was then manually re-modeled as well as the overall contour curves based on all end points
Finally all new curves were selected and the 'Network' function then re-created the minimal surface. Mirrowed, merged and 'Full steam ahead!',
which for a sailing boat is probably the most difficult part to accomplish... ;)
Who ever knows a more elegant way to get minimal surfaces to work within MoI is very welcome to give me a note on that!
Jan
3628.305 In reply to 3628.302
one notice the order in which you shared your knowledge!
First you let me blunt my teeth on my own re-modeled and frozen apple
and then you name those goodies ...
The bill of my dentist would have perfectly covered those tools!
Jan
3628.306 In reply to 3628.305
Hi Jan, well those tools are not really everyday use kind of tools for general surfacing, they're kind of finicky and advanced tools that can get the job done if you don't mind spending a lot of money and also time involved in learning all the ins and outs of operating them.
That's because the "create apples from applesauce" direction is just not a very natural path to work with things...
So they probably are not a practical solution for you unless you are focused on reverse engineering surface models from laser scanned objects as your primary focus for your work.
-Michael
3628.307 In reply to 3628.289
Hi Jan - re: golden ratio snap onto a line, I've cooked up something for that here:
script: /* Set golden ratio snap on a selected line */ var crvs = moi.geometryDatabase.getSelectedObjects().getCurves(); var pp = moi.ui.getActivePointPicker(); if ( crvs.length == 1 && pp ) { var crv = crvs.item(0); var start = crv.getStartPt(); var end = crv.getEndPt(); var phi = (1 + Math.sqrt(5)) / 2; var factor = phi / (phi + 1); var v = moi.vectorMath.makeVector( start, end ); v.scale( factor ); var pt = moi.vectorMath.add( start, v ); pp.addSnapPoint( pt, 'Golden' ); v = moi.vectorMath.makeVector( end, start ); v.scale( factor ); pt = moi.vectorMath.add( end, v ); pp.addSnapPoint( pt, 'Golden' ); }
Copy that whole thing and paste it into the command part of a new shortcut key.
That will then make it possible to use a new golden ratio snap onto a selected line while you are inside of any drawing tool (like draw line, draw point, etc...).
To use it, before you start the draw tool you must first select the line that you want to use for the ratio and it should be the only selected curve object.
Then start up whichever drawing tool you want and when it is asking you for a point to place, then press the shortcut key that you assigned the script to and it should give you a snap like so:
I hope that's helpful for your work!
3628.308 In reply to 3628.303
Hi BurrMan,
that really is interesting! Thank you for that!
It seems this Rhino plug-in does a really good job in creating a NURBS model based on
polygon meshes.
By the named price of EUR 400 for this tool I am not going to ask you or Michael what the
'real ones' may cost.
But I like to try out the demo versions, yet before that I have to get use to Rhino first,
which I just recently installed in its free Beta version. At the moment I have even a hard
time to draw a circle with this program and by this I do not even care about where on the
screen this happens... ;) So first steps first.
A true need for this tool I do not have besides my plain interest. The thought so started
by the initial idea about 'minimal surfaces' within MoI and Michael's efforts to make me
understand why that would sort of 'bust the scope' by the complexity of its genuine nature
and that also a work around by polygon meshing would also run into its own complexity.
But it is always good to know what tools are available, so thanks again for this link!
Jan
3628.309 In reply to 3628.307
this is really a beautiful script!
Thank you very much for it, as it will really help to work with the 'golden ratio'!
And because 'G' is already in use for your 'golden rectangular' script, I choose
'L' in memory of Leonardo Da Vinci ... :)
I already played around with it and noticed two interesting effects so far.
If used on a an angeled line both snaps appear perfectly but interestingly the
scrips seems to interfere with the perpendicular help-line from this point, as
this option does not show up in activated 'golden snap' mode.
But this is no problem, as once a marker line is drawn on a golden snap, the
perpendicular help-line reappears in a second step of sketching.
The other interesting effect appears on curved lines:
The 'golden snap' also appears here and indicates the golden proportion of the
projection of that line. I will see if this behaviour will be constant for any curved
line and its projection, as this also offers an interesting possibility to work with!
So thanks again for your 'cooking' as it really makes working with the 'golden ratio'
taste much, much better! ;)
Jan
@Michael
Cool new script: a golden one! ;)
Seems
For a line find 2 golden points: cool
For curve find only one out of the curve (when it find ;)
@Lejan
About Sketchup for all that curves: Loft, NetWork, Surfaces...etc take the free versatile Fredo6's Curvy loft!
http://forums.sketchucation.com/viewtopic.php?t=28586
EDITED: 13 May 2012 by PILOU
3628.311 In reply to 3628.310
Fredo6's Curvy loft
thanks for the help with SketchUp, but this program and I are just not made for each other... ;)
The graphics in a modern 3D modeling program should just not remind me on my good old
Atari 600 xl, which pretty much did the same only with less colors... ;)
Jan
< are just not made for each other
It's nevertheless the more easy 3D program that you can find :)
3628.313
I use the curves and the planar command in moi3d to make virtual friskets in Artrage.
It would be helpfull if i could see the Artrage canvas through the Moi3d viewport.
When i have finished the job in Moi,then i use copy-paste to place the result in Artrage.
Question : Is it possible to make the viewport transparent (like a alpha channel color), but not the cuves.
I did get inspired by this application : http://www.ptc.com/product/creo/sketch/
3628.314 In reply to 3628.308
Hi Lejan,
""""""""""""""""""It seems this Rhino plug-in does a really good job in creating a NURBS model based on
polygon meshes.""""""""""
Be sure you are looking at the "standalone" version.. They dont need Rhino and are a bit cheaper.
Here is a link to the open mesh one to try:
http://www.resurf3d.com/mesh2snurbs.htm
This one works on obj closed forms:
http://www.resurf3d.com/Objmesh2solid.htm
But it will be more of a "fitting" than a re-creation... I didnt put enough time into the obj one to really be able to speak to it's output.. Maybe you can make the demo work well and report back!
Added ;)
http://moiscript.weebly.com/golden.html
PS About the Golden Rectangle : Snap Straight must be enable!
Show messages:  1-15  …  236-255  256-275  276-295  296-315  316-335  336-355  356-375  …  436-442
