Top 5 Features list for V3 !
 1-5  …  226-245  246-265  266-285  286-305  306-325  …  426-442
3628.266 In reply to 3628.264
That sounds interesting, yet I assume that working with scripts does not comes naturally to anybody, especially for the more creative and mainly 'visual' people.
I think if such functionality would be provided it had to be already implemented in MoI for easy and intuitive use. Otherwise all this interesting methods and
models would be accessible for the creative AND 'programming' affine people only ...
The question is, if such mathematical methods could be made 'intuitive' at all, even though they describe 'natural' formations.
3628.267 In reply to 3628.266
@Lejan ;)
You can type an expression or formula into the numeric edit fields that are asking for distance or radius values.
For example when you are drawing a circle for the radius you can type 15/4*2 and the result 7.5 will be calculated for you.
Another example is if you're drawing a line, you can type <360/12 to set an angle constraint of 360/12 = 30 degree angle snap for that line.
You can also use functions like sin - for example typing in sin(45) will calculate the sin of 45 degrees. All trig functions take angles in degrees. Angle input in radians is available by prefixing the function name with an underscore character, for example: _sin(PI/4). Any of the functions on the JavaScript "Math" object are available for use, including: sin(), cos(), tan(), sqrt(), pow(), round(), random(), the constant PI, and also rad() which takes a parameter in degrees and returns it in radians, and deg() which takes a parameter in radians and returns it in degrees.
You can also type in a "relative expression" to modify the value of an edit field that has previously been initialized to some other value. To make a relative expression, start it with one of these symbols: + -- * / which will alter the value by the given amount rather than inputting a completely new value. So for instance in a grid size input field you can type /2 to modify the existing value by dividing it by 2. Note that for subtraction a double minus sign is used to avoid any conflict with entering in a regular non-relative negative value.
You can also use expressions for x,y,z point values. If your regional settings for the operating system uses a comma character as the decimal point separator for numeric values, then surround each coordinate with parentheses to separate them, for example: (2+2)(5/2-1)(5).
So just Press TAB and write (1+ sqrt(5))/2 and you will obtain 1.618034
Moi write only 6 decimals on external but must calculate on more in internal
You can do that before draw a line or after
- Click first point ...draw your formula (1+ sqrt(5))/2 (By TAB ...) click the second point aligned on any direction
or
- Draw any line : Select it and click on the Dialog Info Box (Right top corner pannel) write the formula inside the Length box
So for a Rectangle with a diagonal = Golden number (it's not Golden Rectangle just a construction for apply the formula of the Golden number)
Draw an horizontal line anywhere with the formula above (will be the diagonal)
Draw any Rectangle anywhere
Transform / Orient / Line-Line
Pick 2 opposed corners of the Rectangle
and click the 2 points of the Line ;)
If all is good you must have a Rectangle with a diagonal = Golden Number ;)
EDITED: 10 May 2012 by PILOU
Many French people are asking for "Measurement drawings"
3628.269 In reply to 3628.267
@PILOU
And that's exactly the point! Not many artists and designer happen to be rocket scientists and many of them are still looking back at their math class at school in sheer horror! ;)
Also 'creative folks' do not always like to read through manuals, faq's or forums like this one, even though it would help them without a doubt.
I do appreciate your detailed explanation and examples about the capabilities of MoI to process formulas, yet this way of finding any 'point of interest' for proportion or distribution
simply interrupts any free flow of sketching and will probably overstrain the majority of people who think mainly in their right brain hemisphere... ;)
Working with MoI I really like just because of its beautiful design in terms of simplification and I assume it is designed this way for all of those creative people who do not own
any degree in engineering or science and do not intend to get one just to operate their 3D design software somewhat properly.
I just started to look into Rhino for Mac and it became quite clear already how much more thought was implemented in MoI to get a good visual result from brain to screen intuitively.
Maintaining simplicity while keeping full functionality is a challange for any good programming design and takes probably a good portion of the overall development time.
For now you got me interested in using MoI for a calculator so I will practice your examples, but only because I recall that tan() got not much to do with some leasure time at the beach ... ;)
3628.270 In reply to 3628.269
Hi Lejan,
Can you give me an example of how you would use the 'golden ratio' in artistry? It appears to be a math point of distribution. How would an artist know/need to use this intuitvly? Is it something taught to artists to use (maybe during setup or something) to do scene/figure scaling by eye or hand? I wanted to understand it's purpose.
3628.271 In reply to 3628.270
Hi BurrMan,
even though the definition of the 'golden ratio' is mathematic, it surly reflects certain principles of proportion found in nature.
Depending on your personal understanding of artistry, in mine, one of the main aime is to be 'pleasant' to many beholder.
So if you are in the process of 'composing' art or design you could certanly use principles which have proven valid for some
while to be seen as 'pretty' for many. Those principles can be found in nature, as we are part of and therefore influenced by it.
Symmetry, asymmetry, coloration, shape - you name it - can be found within nature and many of those are quite appealing
to most people.
By using such principles within artistry or design is certainly no guarantee that the outcome will be outstanding, yet it may help
to avoid total failure in some ways. Again, all of this depends on ones taste and liking, so there is not much to argue about if
such applied rules is good or not. In my eyes it definitely is a good point of orientation and to start from, yet it schould not supress
any other ideas possible.
The 'golden ratio' is also taught to artists, designers, architects as one way of harmonic subdivision of length, area and volume
and can be found in artwork and architecture of the past and at present.
If you are interested, you can find some examples in which it was used here:
http://jwilson.coe.uga.edu/EMT668/EMAT6680.2000/Obara/Emat6690/Golden%20Ratio/golden.html
Very famous in using the 'golden ratio' is Leonardo Da Vinci who also sketched the proportions of an human body which became
quite popular even today. Also in his well known painting 'Mona Lisa' this rule can be found, but again, this is not the reason for
the success of this picture, it just became, cleverly used, a part of it.
Size: 114.8 KB, Downloaded: 54 times, Dimensions: 737x1070px
Size: 61 KB, Downloaded: 42 times, Dimensions: 219x290px
3628.272 In reply to 3628.271
Thanks Lejan for the response.
"a proportional setup" method (Basically)
I have bookmarked this for myself. :)
3628.273 In reply to 3628.263
Hi Jan - re: Golden ratio snap - that's definitely an interesting idea. The problem I see in your example image is that there is a kind of implicit orientation used in your snap there:
The orientation meaning that you've decided that the left-hand side of the line is the "start" and the right-hand side is the "end", and that the golden ratio spot should be placed just on the side towards the end I guess?
This kind of orientation dependency is somewhat problematic because I'm not sure what to do with lines at any arbitrary rotation for example - other snaps on to curves do not have that kind of orientation dependency on them so that could be a problem.
Another issue is that it's not necessarily good to have too many snaps that are automatically on all the time because snaps tend to prevent the free placement of points in a nearby zone to the snap. So this might be something that I would think more of targeting as a plug-in tool that you could activate with a specific shortcut key rather than being an additional totally built in snap.
Anyway, those are a couple of issues involved...
3628.274 In reply to 3628.273
In Sketchup you have this snap but only for the rectangle during its drawing : maybe sufficient for the Golden number ?
Or can be also added during the "Helper line" in Moi ? (similar of the Middle Snap Line first level) ;)
A very artistic esoteric snap :)
Drawn in Moi ;)
This is this rectangle : Red square on the left - Side turned-down from the middle of the side's red square --> gives the new side on the right = Golden Rectangle
(Big side + Little side) / Big side = Golden Number = 1,618 033 988 7....
EDITED: 11 May 2012 by PILOU
3628.275 In reply to 3628.274
In MoI you can set up the same thing - add a shortcut key (maybe for letter G for golden snap?) and for the command part paste in the following script:
script: /* Activate golden rectangle snap */ var pp = moi.ui.getActivePointPicker(); if ( pp ) { pp.clearStraightSnapAngles(); pp.addStraightSnapAngle( Math.atan2( 1, (1 + Math.sqrt(5))/2 ) * 180/Math.PI, 'Golden' ); }
Then when you are drawing a rectangle, after you have placed the corner point hit the G key if you want a golden rectangle and you should get a snap line like so:
Note that it will only work correctly if you go from lower left to upper-right drawing direction and not if you go from right to left.
3628.276 In reply to 3628.275
< In MoI you can set up the same thing
Cool !
That was speedy! :)
About the Helper lines for a line between the 2 red points: Line = 2 segments A & B
2 green points possible for a Golden division (Line A+B or line B+A)
3628.277 In reply to 3628.275
< Note that it will only work correctly if you go from lower left to upper-right drawing direction and not if you go from right to left.
Seems that works in any direction :)
Click the first point of the Rectangle
Call the script
Works like a charm! :)
Each rectangle were drawn from the center so in any direction
Edit Ah yes you have the snaping but not the Golden good result !
So draw from lower left to upper-right and Rotate as wanted :)
3628.278 In reply to 3628.275
""""""""In MoI you can set up the same thing - add a shortcut key (maybe for letter G for golden snap?) and for the command part paste in the following script:"""""""""""
Wow a Fibonacci snap!
This is very cool, Thanks Michael.
Marc
3628.279 In reply to 3628.273
your comment about my drawn example is right, as it shows only one of the two possible golden snap points
on this line. But it was Photoshopped to visualize the basic idea and the rest of it was stated in the text.
If such snap option would be implemented it would simultaneously display the two golden snap points on any
given line, so the orientation dipendency of that line would not be of any concern. And the the user (artist,
designer) would always have both options to choose from.
And even with both snap options displayed one could easily distinguish the 'major' from the 'minor' section
by simply choosing the implicit orientation on ones mind.
Actually, by thinking into this, it could even spread a new discussion among mathematicians if that new
created 'inbetweeny' section may hold its own mysterium in nature which has waited to be revealed since
Leonardo's times... ;)
Collecting this snap option (and maybe similar others) as a plug-in would be a perfect choice and could be
turned on/off whenever needed.
I am no mathematician, artist or designer by profession, so there might be many other interesting proportion
or distribution rules out there which could be useful in the field of 3D modelling. And if you are interested
maybe this forum can collect more of those for a 'nice to have one day' idea box... ;)
bemfarmer already mentioned scrips about 'Vogels model' and 'logarithmic spirals' which would be great to have
also without even knowing how to get a script running within MoI.
What I recall from the 'golden ratio' is, that it also applies for circles and is therefore rightly called the 'golden angle'.
This golden angle divides the perimeter of a circle into its major and minor section in analogy of a straight line and
by doing so it formes the 'golden angle' of 137.5°.
Because I don't know how MoI handles and defines circles I wonder if such angle could be clearly identified as a
snap point at 137.5° without definding an additional start point on its perimeter and its direction of orientation.
In any way I am glad you liked the overall idea and, who knows, maybe one day you surprise your customers
and community with a mind blowing and easy to use plug-in about 'Natures Little Secrets of Beauty'... ;)
Just let us know when to start collecting ideas!
Size: 38.4 KB, Downloaded: 28 times, Dimensions: 228x224px
3628.280 In reply to 3628.273
By the way, for all of you who are interested in this concept of nature's laws of construction
there is a beautiful animated short movie created by Cristóbal Vila shown on vimeo:
http://vimeo.com/9953368
Just get inspired ...
Jan
3628.281 In reply to 3628.273
Minimal Surfaces
Another idea for MoI, by stressing nature again, could be based on 'minimal surfaces' as an optional style for the 'loft' tool.
Instead of choosing 'Normal', 'Loose' or 'Straight' a new 'Soap Bubble' function would calculate a surface in between
profile sections which would gain to be minimal in its surface area and therefore in its lowest 'energy level' as if it was a
soap bubble skin.
Maybe an accurate calculation of each of those surfaces would take an infinite time to be solved, yet there might be
simplifications possible to get a 'close to' but faster result.
The outcome of such a function, besides its inherent beauty, could be useful to those who seek for a good optimisation
of their models in terms of minimalism.
Size: 7.4 KB, Downloaded: 58 times, Dimensions: 300x225px
Size: 7.1 KB, Downloaded: 58 times, Dimensions: 300x225px
3628.282 In reply to 3628.279
About the Golden Angle you can enter directly this 137.5 in the numeric keyboard for Arc Circle angle ;)
3628.283 In reply to 3628.282
@ Pilou
Yupp! I tried, it worked!
Yet the idea is not that MoI isn't capable of somehow getting those 'points of interest' with its 'in build' tools - indeed you do get them.
The idea for this wish list is to get those points suggested automatically - if you want them to have - without doing any 'math', additional
constructions or 'typing' at all.
This way you could simply choose from those suggestions as you 'fly' and you would not get 'off focus' of what you are doing setting up
workarounds or the system itself.
Thanks to your todays comment on Sketchup and Michael's script response for the golden rectangle it has never been easier to me to work
with this concept within MoI. So thanks both of you! And it also showed what a system could provide once it is enabled to.
To finally get there I had to figure out first how to get a shortcut running in MoI, which took some time, and may not be welcomed by
other users which are less involved or interested in this sort of things... ;)
Jan
3628.284 In reply to 3628.283
Hi Jan,
This part is actually quite simple, no advanced math required! :)
Just go to Options > Shortcut keys, and on the very top of the screen there is a big "Add" button - push that to add in a new shortcut key entry at the top of the list.
For the key just type in whatever key you want to trigger it, like G might work well for "golden section".
Then for the command part you just copy and paste in the script I posted above.
That's it - just "Add" and then type in G and then a paste, not really all that difficult!
In the future I do want to actually streamline the process of installing new scripts somewhat more, but I can't quite understand why these pretty simple steps would be so harsh and unwelcome like you're kind of describing them?
The whole process of just doing 3D modeling is many times more difficult than this part...
3628.285 In reply to 3628.283
Hi Jan,
The problem though is that different people have a lot of different needs - a whole lot of people don't have any need to have a golden rectangle snap, and for those people having the snap kick in that they don't want or need is actually a negative thing instead of a positive thing.
So there tends to be a kind of balancing act on things like that - if I just threw together every single possible kind of feature that every separate person needed all turned on and combined into Moi all at the same time, that's a recipe for complexity and a "bloating" of the UI.
It's been a big goal of MoI to keep things streamlined and easy to use and avoid that type of bloating.
So in order to maintain those goals, it's an intentional thing that some types of features may not be included by default and may need some minor adjustment like the setting up of a shortcut key with a script pasted on to it in order for the functionality to be triggered.
I can understand how it would be cool if MoI had every single thing that you in particular wanted to do all set up for it right out of the box, but please keep in mind that MoI is used by a lot of different people for a lot of different kinds of things and so that kind of specific individual configuration _as a default_ is probably not likely to happen.
Just wanted to give you some more background information on some of the design constraints and problems that I have to consider when adding stuff into MoI - it's really easy to actually ruin the simplicity of MoI simply by tacking on too many things that are all competing for attention by default.
Show messages:  1-5  …  206-225  226-245  246-265  266-285  286-305  306-325  326-345  …  426-442
