nose
All  1-5  6-8
3621.6 In reply to 3621.5
Hi dojn, you'd probably want to use that technique I showed earlier for making a larger amount of the whole cockpit.
But there are a couple of different things you can try apart from that as well.
One is to model the tip as a separate surface using Revolve, which makes for a nicely rounded shape at the very end, like this:
Then scale that so that it matches the end of your current shape better:
Then delete any end caps so that the surfaces are open at the ends, and select these 2 edges:
And run Construct > Blend to create a new smooth surface connecting them, like this:
I've attached a 3DM model file with one result from that.
Another thing you can try is to extend your shape a bit longer, past where you want the rounded tip to be instead of stopping it before there, and then cut off the end with a surface and fillet them, that's similar to the previous steps that I was showing.
3621.7 In reply to 3621.5
Another possibility from your curves :)
(I say paste = Move the curve to existing points )
EDITED: 19 Jun 2010 by PILOU
3621.8
Thanks a lot to you both,
I'll try all methods..
hope showing you the result asap.
cheers,
dojn
Show messages: All  1-5  6-8
