Web site update
 1-4  5-24  25-44  45-64  65-73
3617.45 In reply to 3617.42
Hi eric,
> I was just playing with Chrome Browser. It does not ask me
> for a login ... just goes directly to the forum.
> It does not display 'unread discussions' as an option.
That means that it was viewing the forum as a "guest" user. Unread messages are not tracked for guest users, only for logged in users.
When you're viewing as a guest, there will be a login option on the top bar here:
I think once you have logged in once it will then take you to the login page initially after that, or something along those lines.
If you still run into problems with not going to the login page initially, you may need to alter the link that you are using to access the forum initially, try this one:
http://moi3d.com/forum
3617.46 In reply to 3617.43
Hi olio,
> Why not outsource website development, and focus on V3?
Same reason various other things are not outsourced - it costs a lot money and it also can take quite a bit of time involved with back and forth communication to make sure I would get what I wanted.
I may do it at some point in the future though.
3617.47 In reply to 3617.46
Hi Michael, the triple scroll bar is fixed .
I've added a nav strip at the top of the message display for going to different pages of messages in the thread in addition to the nav strip at the bottom.
So now you don't have to scroll to the bottom to go to different pages.
3617.49 In reply to 3617.45
thanks Michael ...
That works!
eric
A button for customise color background?
3617.51 In reply to 3617.50
No, unfortunately it takes a lot of work to do that, since it would require different versions of various images.
I've just a made an update of the forum threads list, got rid of the big purple tab thing that used to be at the top.
On the French Moi "Home" forum, there is not the cool image of the "Moi Sculpture" with light bulb ;)
like here http://moi3d.com/forum/
3617.53 In reply to 3617.52
I should be able to fix that up tomorrow.
3617.54 In reply to 3617.53
THX :)
3617.55
Not so sure about those little blue/purple bubble-thingies at the top of the forum pages. Kinda like champagne bubbles meets molecule bubbles. Doesn't have consistency with some form of CI/CD. I like the face and the light bulb......but maybe some other forms (i.e. boolean shapes) instead of bubbles. Just my 2 cents from a designer's eye. I hate to harp on your webpage design because your program is so damn sexy. :)
Gyro Gearloose grand father of the bulb ;)
3617.57 In reply to 3617.55
Hi Tree, yeah I'm not so sure about those bubbling warts either, but after trying several different kinds of things I kind of liked something that hung down from the top edge it kind of keeps it out of the way of the text more.
I kind of want to put something in that spot just to have a bit of texture.
Here are some of the other doodads that I have tried:
But I haven't tried many hanging down ones yet.
The crop circle one on the right is a lot more boolean-like though, they were actually made directly with booleans.
3617.58 In reply to 3617.57
I like the title doodads... FYI
3617.59
Your site is looking good to me...
3617.60 In reply to 3617.52
The French forum should now also have the MoI sculpture logo guy now.
3617.61 In reply to 3617.60
Bravo!
The search function in the forum has been updated.
Searches will now be conducted on thread titles in addition to the message body.
I also added a new control here:
This can be switched so that only titles will be searched and not the message content:
So for example now it is possible to do a search for threads containing "WIP".
I've also tuned up the search page so that all the search parameters will keep their values intact when the search is completed, rather than them all resetting back to default values like it previously did. If you want them to reset, just click in the "Search" link in the top toolbar again.
This along with the added nav bar at the top of the messages list finishes up my todo list for functional stuff to add to the forum. If you have any other requests, now is the time to speak up! :)
3617.63 In reply to 3617.62
seems now all research don't work on the French forum ;)
3617.64 In reply to 3617.63
Hi Pilou, do you know if it used to work before, or is it possible that it has never worked over there?
Show messages:  1-4  5-24  25-44  45-64  65-73
