Web site update
 1-14  15-34  35-54  55-73
Ok, the font size should be back to the same as it used to be.
If you've moved the size up or down, you can use Ctrl+0 (Ctrl+Zero) to return to the default size again.
3617.37 In reply to 3617.36
Hi Pilou - Safari is based off of the WebKit engine same as Chrome.
3617.38
I use Safari 5 ... and all is fine ;)
Size: 164.5 KB, Downloaded: 29 times, Dimensions: 1571x850px
3617.39 In reply to 3617.38
Hi ycarry, yup the size issue should be resolved now.
Just a few more tweaks to do...
3617.40 In reply to 3617.39
I got some strange triple scroll bar depending of the page resolution, IE8/Win7 64
EDIT: Ok the zoom page was at 105%, everything turns ok at 100%
EDITED: 3 Dec 2015 by PAQ
3617.41 In reply to 3617.40
Hi PaQ,
Weird one, thanks for reporting this.
It looks like a bug in IE8 but I think I have tweaked things now to avoid it, can you please try pushing F5 to reload and then see if adjusting the zoom does not cause the triple scroll anymore?
3617.42 In reply to 3617.20
Hi Michael ...
I was just playing with Chrome Browser. It does not ask me for a login ... just goes directly to the forum.
It does not display 'unread discussions' as an option.
I'll just stay with Firefox ... but thought you should know these things.
cheers,
eric
3617.43 In reply to 3617.42
Why not outsource website development, and focus on V3?
3617.44
I use Chrome and get the forum logon screen every time I visit the forum from a direct link to the forums. I also get the unread discussions option.
Re out sourcing website development. I doubt Michael spends a huge amount of time on the website. What we've got is pretty straight forward and the few changes he's made probably don't take too much of his time. A web developer would probably want to add all sorts of bells and whistles rather than keeping things simple and easy to use.
Good to see the font size reduced. It was far to big for me at default size.
3DKiwi
Homepages: 3dkiwi.co.nz & C4D Cafe
3617.45 In reply to 3617.42
Hi eric,
That means that it was viewing the forum as a "guest" user. Unread messages are not tracked for guest users, only for logged in users.
When you're viewing as a guest, there will be a login option on the top bar here:
I think once you have logged in once it will then take you to the login page initially after that, or something along those lines.
If you still run into problems with not going to the login page initially, you may need to alter the link that you are using to access the forum initially, try this one:
http://moi3d.com/forum
3617.46 In reply to 3617.43
Hi olio,
Same reason various other things are not outsourced - it costs a lot money and it also can take quite a bit of time involved with back and forth communication to make sure I would get what I wanted.
I may do it at some point in the future though.
3617.47 In reply to 3617.46
Hi Michael, the triple scroll bar is fixed .
I've added a nav strip at the top of the message display for going to different pages of messages in the thread in addition to the nav strip at the bottom.
So now you don't have to scroll to the bottom to go to different pages.
3617.49 In reply to 3617.45
thanks Michael ...
That works!
eric
A button for customise color background?
3617.51 In reply to 3617.50
No, unfortunately it takes a lot of work to do that, since it would require different versions of various images.
I've just a made an update of the forum threads list, got rid of the big purple tab thing that used to be at the top.
On the French Moi "Home" forum, there is not the cool image of the "Moi Sculpture" with light bulb ;)
like here http://moi3d.com/forum/
3617.53 In reply to 3617.52
I should be able to fix that up tomorrow.
3617.54 In reply to 3617.53
THX :)
Show messages:  1-14  15-34  35-54  55-73
