Length of 3d object
All  1  2-4
3615.2 In reply to 3615.1
Hi Anis,
I was able to create a centerline through copied circles at the surface edges and extend them together. I then established the bend radii by creating three point circles at the outside and inside bend radii edges. The two bends at the end are 60mm and the ones in the middle are 30mm, from my calculations. I then used a script I got from Michael G. to extract the overall length of the tube. The attached file has the centerline geometry and the text shows the overall length.
Hope this helps.
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
EDITED: 4 Nov 2010 by MICTU_UTCIM
3615.3 In reply to 3615.1
Hi Anis, for tasks like this you have to undertake some "reverse engineering" type processes as Michael T described above.
Since you don't have the original rail, you need to create a replica of it before you have something that has a measurable length.
3615.4 In reply to 3615.3
Hi again Anis,
The script I spoke of was the total length of the joined center line geometry, not the tube geometry itself. Just wanted to clarify.
Michael T.
Show messages: All  1  2-4
