Filleting Problem
All  1-4  5-9
3608.5
Hi Steve
I made the block at the front a simpler solid, I would cut out the air scoop after with a boolean difference. Also if you a mirroring make sure the 2 control points near the border are horizontal or you will have a crease when you mirror (see attached picture. 2 highlight point should be aligned). This is the same with your other profiles. also make sure your profiles are aligned at the center Z axis. Its worth checking before you build you shapes because if they are out you will run into all sorts of problems later on.
Hope it helps a bit. Looks like you will also have a tough area with the wing transition, good luck. Look forward to seeing the progress.
Jamie
3608.6 In reply to 3608.4
Hi Steve, also another thing that could possibly help you is if you select the 2 surfaces that share that edge, and use Edit > Separate to break them apart from the main solid, but they will still be joined to each other.
With that situation the filleter no longer has the complexity of collisions with the surrounding side surfaces to try and deal with for filling in holes, and you can create a fillet successfully similar to surface/surface fillet that way.
It will be a kind of long extended piece like this:
But it may give you enough raw material to work with and cut down.
3608.7 In reply to 3608.6
That last option seems to be a goer. It is difficult to create a nurbs version of what was very simple in sub-D. Ive tried this in Solidworks and found it virtually impossible. Good job Sidney Camm wasn't using CAD!
3608.8
Very interesting, I did'nt know fillet could be used in this way with surfaces.
Marc
3608.9 In reply to 3608.7
Steve,
That's true. Some shapes just naturally lend themselves better to different technologies. There's no "right" or "wrong" here. Sub-ds, nurbs and solid modeling can all do terrific stuff, if you play to their strengths but can be equally frustrating when you get down and dirty with their weaker sides.
Show messages: All  1-4  5-9
