Need advice joining complex surface
 1-10  11-30  31-41
3593.31
Hello d3print,
It wasn't difficult at all. I just selected the entire lump of geometry and hit the button. I checked the geometry of the model and even after that there are a bunch of problems. I have a little free time and am trying to use it as a challenge to sharpen my skills. It may not turn out anyway but at least I will get some practice. It seems the edges are sort of sloppy and gapped, overlapping, etc. in a few areas among other things and the rounds look messed up in many places. SCE has some great defeaturing tools so once I hopefully get this into a solid I'll be able to tighten that up. I'll try to isolate the pieces and parts from the largest mass of the model to indicate what surfaces are causing problems.
3593.32 In reply to 3593.31
Something that was built to a loose tolerance plus at the same time has small sized edges or features in it can tend to be problematic.
3593.33 In reply to 3593.30
Hi Burr,
> "STEP" up to solids
Yeah that can often help, particularly with not having to join things.
Unfortunately STEP has some totally different areas where things can go wrong in - the way trimming boundaries are specified in STEP files, only the 3D curves of the edges are contained in the file, leaving the UV space trim curves to be calculated by the application. That calculation can be fairly difficult in some circumstances, particularly in seam areas of closed surfaces if the trim curve wanders slightly back and forth over the seam.
Also the STEP mechanism allows for things like a single trim curve that crosses over a seam in a closed surface which has to be split for regular NURBS topology. That can again be a difficult calculation if the edge just barely grazes the seam or hugs along it for just a little bit instead of crossing directly over it, stuff like that.
So there are some trim curve calculations and processing that still has to happen with STEP files in order to get it into a normal NURBS topology, and along with any kinds of fairly complex calculations there is potential for things to go wrong in grazing / barely touching / overlapping kinds of situations.
It sure would have been nice if the STEP authors would have made it a more direct container of simple NURBS topology, that would have made it a more ironclad data transfer mechanism.
3593.34 In reply to 3593.25
Hi Burr, so I was experimenting some with different internal options for surface joining, and by turning on an option for squeezing together small edges I was actually able to get your wheel thing there joined into a solid (just 1 surface needed to be trimmed), it is attached here.
But unfortunately I have also seen that "squeeze small edges" option cause some kind of orientation problems in some other cases, that's why it is not turned on currently in MoI.
That seems to be the actual problem with the model though, not that the endpoints have that little overlap, but that there are some little super tiny micro edges in the trimming boundaries, actually at a 90 degree turn from their surrounding edges making for a really messy situation.
Here I have tracked down just one of them:
In this area here:
If you zoom in you can see the 2 larger edges have a kind of criss-cross arrangement (like I was showing earlier, this is another angle on the same kind of thing):
which is not really great compared to touching nicely, but actually the ends of the criss-cross are within 0.0007 units of each other which is within tolerance so that is actually by itself not going to interfere with joining.
But notice the circled area, there is a little spec of yellow in there - that's actually another edge in there. Here i have zoomed in more closely on it:
And here it is unselected so you can see it more clearly:
So that's a terrible super tiny little edge hanging off one of those larger edges, and it is at some kind of 90 degree angle to the overall boundary shape, just really nasty to deal with trying to join that to something else.
That little micro edge is only 0.0000007 units long - this becomes bad when the entire edge is way smaller than the tolerance, it becomes difficult for the joiner to figure out how its endpoints should relate to other way larger edges that it is trying to join it with.
So anyway, that's what's going on with your example - it's not sags, but rather badly formed trimming boundaries with tiny micro edges in them.
At some point I could probably cook up some kind of "edge repair tool" that would do things like try and just remove little tiny micro edges like that to get rid of them.
3593.35 In reply to 3593.34
Thank you very much. I guess I didnt look at it very closely, I thought I looked for that kind of stuff. But then again, 0.0000007 is very small and perhaps I didnt look close enough!!! LOL
Not to drag this out, but just a finish up for me... It appeared this iges file came from NX also, and I was wondering about this poor geometry creation. It appears to be a simple hole punched with a fillet on the edge. Could this type of issue be getting created by the filleter mechanism? I mean, when I punch simple holes like this in a revolve with MoI and fillet the edges, When the fillet succeeds, I get good surface quality. I realize that if I create a poor curve to punch my hole, this would create this kind of issue....But if I create a simple circle, it would surely be avoided!!! Could it be a loose tolerance setting in NX that would allow it to create these anomolies by just "slapping things together"?
I know there are many variables, and you are not a mind/model reader...Just looking for a "best guess" situation or more brain picking on your judgement of what has happened here....Perhaps these are just bugs in NX5 as that is old now compared to 7.5.
3593.36 In reply to 3593.35
Hi Burr, well it's hard to say what's created that.
Maybe it's even something that the IGES importer itself is inserting in there because it thinks that there is too large of a gap in there, I'm going to see if that is a possibility.
3593.37 In reply to 3593.22
Hi Anis,
Well I got to look at the model and received the same results as everybody else. One thing that the higher end packages do, with these repair wizards is list all the faults and present them to you to fix. With the package I used it would present about 50 areas that need to be addressed. Perhaps a day of working the model over by someone experienced.
Anyway, thanks for letting me look.
EDITED: 26 Aug 2011 by BURRMAN
3593.38 In reply to 3593.28
Is this for rendering purposes?
No, I want to create core & cavity.
3593.39 In reply to 3593.35
Hi Burr, so actually that particular line is being created by the IGES import code.
The reason why though is that the file is marked as being built to a tolerance of 3e-7 (0.0000003) and the IGES reader seems to take it at its word and considers gaps much larger than that to be large enough sized things to be filled in, while in actuality the data in there is nowhere close to that accurate, more like 1e-3 between endpoints and stuff like that.
This tolerance value is at the start of the file here:
If you edit that to say something like 3.037E-003 instead, then at least some of those micro lines will be avoided from being created, but there still seems to be a few other ones in there apart from that.
I'll have to send this over to the HarmonyWare guy and ask him if its a good idea to actually trust that tolerance value in the header since it is completely off in this case.
3593.40 In reply to 3593.37
Hi Burr...
Thanks for looking at the model to examine.....
So the conclusion is I need to repair some bad area manually or request to our client STEP format.
Also looks like no software that can import the IGES file smooth and solid.
Thanks for everybody that help me to solve this case...
Regards,
Anis
3593.41 In reply to 3593.40
""""""""So the conclusion is I need to repair some bad area manually or request to our client STEP format.""""""""""
Yes and all the other "Solids formats like SAT. I would also think that with this info, there may be some functions in NX to "Prepare to export" like some kind of analisys and repair on the "Native geometry" BEFORE the export.
Some of the things Michael is describing here are "functions of import" and just how the process works with the data and parameters presented.
If all you have is this file, it will need to be worked. Actually, the program I used has "2 different methods of importing of iges and produced 2 different results. Possibly the STEP or SAT imports may handle things better. Michael even just discussed manually changing the tolerance value in the iges file to get a different result that may produce a model that is easier to repair on import.....
The other thing is you mention you want to do Core and Cavity. I'm no expert on this, but it would seem to me you want to do parting lines anyway...So halving the model into 2 seperate surfaces may make for a better resulting import or easier to fix whats left????
Burr
Show messages:  1-10  11-30  31-41
