WIP Railing
 1  2-21  22-40
3579.2
The eye picks up on symmetry. If parts of your design are symmetrical and others are not, peoples brains will not have a good time looking at your design.
Rainer
3579.3
Hi Rainer,
i`ve tried to stay symmetrical (right part is mirrored and offset) and it looks strange.
Now i`ve changed it in the way that the problematic part is not symmetrical anymore while everything else remains symmetrical and it looks way better.
I`m still wondering why that is so. I`ve assumed that staying symmetrical would automaticly look good (of course i have seen that it doesn`t).
Size: 229.9 KB, Downloaded: 85 times, Dimensions: 749x1088px
3579.4 In reply to 3579.3
Hi vinced, well sometimes spacing between elements is also important, just symmetry by itself maybe was not enough for your particular case?
I think your new one looks more balanced and nicer in that area than your first one.
3579.5
@Michael
maybe the skewness (?) of the railing is killing the symmetry here?
And here is another try.
Mirrored 45 degrees.
I think the second one looks better because there is more continuity.
Size: 155.6 KB, Downloaded: 59 times, Dimensions: 687x1074px
3579.6 In reply to 3579.4
To add to ideas/inspiration, here are 3 gates I modelled in MoI.
Hope of interest.
Brian
Size: 54.7 KB, Downloaded: 203 times, Dimensions: 800x450px
3579.7
they`re lookin really good. Especially the left one i think would fit to an old house.
How did you model this?
My way was drawing lines, offset, connecting and then extruding them.
I am not aware of any good technique here.
vinced
3579.8 In reply to 3579.5
Hi vinced, well all I can say is that both your 2nd and 3rd one look better to me than your 1st one.
I do maybe like the 2nd one a bit more too.
3579.9 In reply to 3579.8
Yes, just plain hard work!
Here is the 3DM file---feel free to use/adapt.
Brian
3579.10
Thanks Brian,
i`ll analyze it a bit and use it for my inspiration. Looks really great.
@Michael
Yeah i think i`ll go with the second one.
vinced
3579.11
Just a small update.
I`m not sure where i want to go with this.
Maybe the inner part of an old house with many floors.
Size: 145 KB, Downloaded: 102 times, Dimensions: 1000x657px
3579.12 In reply to 3579.11
Here in Adelaide, South Australia, we have many houses, of the 20s?, with lots of cast iron lacework.
Hop[e you can con continue the building to match that good start.
Brian
3579.13
And another update...
The huge block in the background shall become a wall with some kind of door at the bottom. The two pillar-like cubes are placeholder for elevators. I will have to think about how to do them later on. I try only to modell what will be seen by the camera as the scene is already heavy and it will get much heavier when all the floors with the railings are finished.
I want to make the inside dark and shadowy with bright light coming through the door and somewhere else.
@Brian
Thanks Brian. I`ve never been in australia, but i want to visit it some time in the future. I really like that yellowish desert style look of the country. The only thing i don`t like about australia is sharks. Can`t you do something to get rid of them ;-)?
Old buildings of the 20`s here in germany are rare. They have been mostly destroyed. But we have nice old castles. I love old buildings and the stories they tell.
vinced
Size: 194.8 KB, Downloaded: 89 times, Dimensions: 1353x1023px
3579.14 In reply to 3579.13
Lookin good.
What sharks in Australia?
It's all much of a beatup---more dangerous crossing the road
Or still smoking cigarettes!
Brian
3579.15
Meanwhile i get "memory insufficient" or something like that -errors during export.
Not sure how to deal with that.
Anyway, another one ...... until my comp explodes
Size: 234 KB, Downloaded: 72 times, Dimensions: 1163x1074px
3579.16 In reply to 3579.15
Hi vinced,
> that -errors during export. Not sure how to deal with that.
You'll probably need to do the export in different sections instead of all at once.
To do that, select just some chunk of your objects (maybe try half of them at first), then use File > Export, which will write only the selected objects out to the file.
Another thing you can do to help reduce memory consumption is to reduce the display mesh density, you've got quite a large number of curvy objects in your model there, and by default things are set to make a fairly high density display mesh which makes things look nice and smooth but which takes up more memory which can add up when you have a large number of objects.
To reduce the display mesh density go to Options > View > Meshing parameters, and set "Mesh angle" to 25 degrees, and uncheck the "Add detail to inflections" checkbox.
That will make for a somewhat more rough/jagged looking display but it should reduce the memory load by quite a bit.
3579.17
Michael, i`ve already done that.
I`m not sure if i`m able to finish the scene with my actual comp.
3dm-File is 800 MB huge. MOI uses 2.8 GB of my Ram(4GB).
Size: 358.1 KB, Downloaded: 78 times, Dimensions: 1604x1088px
3579.18 In reply to 3579.17
Hi vinced,
I think you can hide several components while working with your model.
Only show component that related to area you working on.
It will save your memory...
3579.19
Also... the detail is starting to make the image very hard to read. Maybe more closeup's.
Starting to come together!
Rainer
PS:Brian... aren't the Saltwater Crocks eating the sharks for breakfast??? Those seem to be quite the beast.
3579.20
@Anis
hiding components only saves memory as long as i haven`t made them visible since loading the scene. When i`ve made some parts visible the Ram-usage increases but it doesn`t decrease when making them invisible afterwards. At least that is what i`ve noticed.
The Ram usage is not so much of a problem until i try to export the scene as a whole, but splitting it up into different parts works.
But i`m not sure if my ram is enough for texturing. We`ll see.
@Michael
something i`ve never thought about before, but is MOI a 64bit application and able to use more than 4GB Ram ? I`m on Win 7 64 bit.
@ Rainer
I just wanted to show the whole object, it`s not the camera view. At the moment i`m doing a test-render. When it`s done i`ll post it here.
The details should be better visible then.
Greetings
vinced
3579.21 In reply to 3579.17
Hi vinced, with something like that where you are continuously adding more and more things which are all pretty detailed you will need to split your project up into multiple separate files rather than having it all in just one single ginormous file.
It looks like you might have a pretty natural division there with 1 separate file for each floor.
Another thing that would help enormously for reducing memory consumption would be to avoid replicating the railing inside of MoI and instead make the duplicates in your rendering program where they could be defined as instances instead of as duplicated raw geometry.
I do want to work on making an instance mechanism in MoI in the future, but many file formats do not have any mechanism in them to transfer instances (for example OBJ and LWO do not support it) so even at that point it may be best to still do it in your rendering program instead.
> Win 7 64 bit.
MoI is a 32-bit application, so it will top out in practice at something like 3.6GB of RAM usage (if you're on a 64-bit OS, more like 1.6GB on a 32-bit OS). Unfortunately it takes quite a lot of work to produce and maintain multiple versions of a program so at least for some time I am not going to try to make separate 32 and 64 bit versions.
Show messages:  1  2-21  22-40
