sweep help
 1-4  5-24  25-44  45-49
3575.45 In reply to 3575.44
Great model ppj, it's cool to see an other modo user enjoying MoI booleans power :)
3575.46 In reply to 3575.44
Hello Michael,
>>Wow, you mean anybody else other than what you work on must be doing "hobby stuff" ? That's a quite patronizing attitude.<<
I did not mention anyone else, please show me where I did!
I think overall that MoI is no good for my work, MoI output is not accurate enough and when the models are taken into the other packages I use there are many errors, yes, the errors are (usually) within the tolerance of MoI, but not for being acceptable for my work (I do not make the rules of what is and what is not acceptable). That is not patronizing, just a fact.
I find it amusing that you jump between examples of this mitering and then just post an acceptable result from the first posted by the OP
Why did you post the example (http://moi3d.com/forum/index.php?webtag=MOI&msg=3575.4) I was replying to (and I though we where discussing), and then not post an example showing a good result with you method?
The first rail/profile posted can easily be done with the various CAD systems I use, even Rhino can give a good\usable result with 5 mouse clicks.
Anyway, have fun.
- Steve
3575.47
Time to close this thread I suggest. It's just going around in circles.
Nigel / 3DKiwi
Homepages: 3dkiwi.co.nz & C4D Cafe
3575.48 In reply to 3575.46
Hi Steve,
You said that the result generated "may be OK for hobby stuff" - however, the result that I posted would be ok for a lot of different purposes, like someone more focused on just quickly getting a model for rendering, or for some design like a piece of jewelry that does not have to be exactly tubular to a tight tolerance, or a ton of different things.
Your statement is basically placing all these other kinds of people's work as just "hobby stuff", even though what they are producing is actually a part of their real job, it's just different from your job.
Of course, I can certainly understand if MoI is not the right tool for your job, if you have specialized requirements then use specialized tools.
Well, there were various different parts to the discussion earlier in this thread, that particular one I was giving an example of how you can't actually have a completely even thickness tube that has a common miter-like joint between 2 pieces that are curving around all over in 3D.
One that matches your definition of within tolerance and not the "oh-so-terrible" result from sweeping between angled profiles?
If so then by all means show it.
If you do a regular 1-rail sweep in Rhino it will produce this result:
If you enable the "Untrimmed miters" option, then it will produce this result:
Note from the slanted isoparms there, that this is a sweep between angled profile curves, which is the kind of result that you had earlier said was totally unacceptable.
Is it suddenly acceptable now?
3575.49 In reply to 3575.46
Hi Steve,
Just curious, what other packages do you use ?
I use NX6 at work and I have done various models in MoI with quite good results when importing into NX, we work to an accuracy of 0.005mm(0.0002") and 99% of the time the models from MoI pass the tolerance check amongst the other surface checks which do well most of the time, if a surface does fail it doesn't take much to fix.
I don't know how complex the models are that you are bringing in from MoI to your other packages but this model I made 2 years ago in V1 passed the tolerance check at 0.005mm, there were a couple tiny objects and a couple of self intersections which where caused by the fillets which took me no more than 5 minutes to fix.
I believe working below an accuracy of 0.005mm is impractical in the real world unless you're into nanotechnology which is an entirely different world altogether.
If your getting a lot of errors with your models maybe try another modeling technique, like, I found I get better results if I use basic curves and arcs where possible instead of a freeform curve where you don't know what degree it is or how many segments it has.
I actually purchased MoI for home use and truthfully, I didn't expect a super accurate solid modeler but in the end it has preformed better than my expectations, I can even say it does better in a lot of areas than some mainstream CAD modelers that cost 10 to 20 times more.
Show messages:  1-4  5-24  25-44  45-49
