I used the display mesh option for getting a lower RAM usage but it dosn't help, but exporting in pieces is the way, I got my model meshed. Thank you. :)
"I'm not sure if you would really want this mesh, as it is kind of messy with things such as T-junctures instead of having all matching vertices along joined edges like an export mesh."
Better a quick bad mesh than nothing. ;) In my case I only need something complex that is visible as base frame. The important part is the upper part of the railroad engine and this is clean geometry.
Thank you for the script too - if I use it than I see at the left corner that 1653 surfaces are selected, but I can't see any highlighted object. Do you know why?
Visualisation for Designer and Architects
| http://www.simulacrum.de |
