Hi Mark, also you could use Boolean difference in this case to slice up the block.
To do that, select the slanted part, run Boolean difference, and select the plane as the cutting object.
That will cut the slanted box into 2 solids, it's slightly different than Trim since there will be pieces of the cutting plane included as part of the result, but you can delete those.
