Dynamic reloading of scripts
All  1-6  7-17
3544.7 In reply to 3544.6
Mike,
Did some more work on this today. I've got all the files needed for using the scripting interface ready to go, including a readme on how to do the installation. I just need to do a test install to make sure it all hangs together. I'll try to get to that tomorrow.
Just wanted to let you know I haven't forgotten about this...
- Dave Morrill
3544.8 In reply to 3544.7
Thanks for your efforts on this. Looking forward to seeing how it all works.
thanks
Mike
3544.9 In reply to 3544.8
Any new developments on this?
Have I missed something?
Really, really, in need of an up to date, complete, Short Cuts and a printout style understandable" shortcut keys" for my desk.
I am just too old--have spent the best part of the last 2 days trying to get my mind into gear to do it and it wont work in my brain.
Brian
3544.10 In reply to 3544.9
Sorry Brian, got sidetracked trying to do some more work on finishing up the Javascript API documentation before releasing the scripting package. But it looks like there is still a lot more left to do there (currently at 73% complete), so I guess I'll have to punt on getting that finished for now, and just get the rest of the stuff ready to ship. I'll set an (arbitrary) goal of Tuesday for getting that done...
- Dave Morrill
3544.11 In reply to 3544.10
That was quick Dave.
Thank you.
I am hoping that the end result for me is something like this.
Is that the aim?
Brian
Size: 82 KB, Downloaded: 60 times, Dimensions: 724x1024px
3544.12 In reply to 3544.11
Brian, I think we have a disconnect somewhere. I thought you were looking for something to allow you to reload scripts dynamically.
If what you want is to display your current MoI shortcuts, the following Python script I just wrote should do it (at least for Vista/Windows 7):
from os import environ
from os.path import join
def key_sort ( l, r ):
    result = cmp( len( l ), len( r ) )
    if result != 0: return result
    return cmp( l, r )
shortcuts = {}
ini = open( join( environ[ 'APPDATA' ], 'Moi', 'moi.ini' ), 'rb' )
lines = [ line.strip() for line in ini.readlines() ]
max_key = 0
ini.close()
for i in xrange( lines.index( '[Shortcut Keys]' ) + 1, len( lines ) ):
    line = lines[i]
    if line[:1] == '[':
        break
    col = line.find( '=' )
    if col >= 0:
        key = line[ :col ].strip()
        max_key = max( max_key, len( key ) )
        shortcuts[ key ] = line[ col + 1: ].strip()
pad = ' ' * max_key
keys = shortcuts.keys()
keys.sort( key_sort )
n = len( keys[0] )
c = ' '
for key in keys:
    if (n != len( key )) or ((n > 1) and (key[:1] != c)):
        n = len( key )
        c = key[:1]
        print
    print (key + pad)[ : max_key], '=', shortcuts[ key ]
When I run this on my system, it produces the following output:
A            = Rotate
C            = Circle
D            = BooleanDifference
F            = Fillet
H            = script:moi.geometryDatabase.hide();
J            = Join
L            = Line
M            = Move
O            = Offset
R            = Rectangle
T            = Trim
U            = BooleanUnion
V            = Mirror
X            = Extrude
F1           = script:moi.launchHelp();
Ctrl+A       = script:moi.geometryDatabase.selectAll();
Ctrl+C       = CopyClipboard
Ctrl+N       = New
Ctrl+O       = Open
Ctrl+S       = Save
Ctrl+V       = Paste
Ctrl+X       = Cut
Ctrl+Y       = script:moi.command.redo();
Ctrl+Z       = script:moi.command.undo();
Delete       = Delete
Ctrl+Shift+C = CopyClipboardWithOrigin
Ctrl+Shift+V = PastePart
Let me know if this is something like what you had in mind...
- Dave Morrill
3544.13 In reply to 3544.12
Sorry mate----all double dutch to me.
I really can not cope with all this script stuff I need just the simple access to --well-- Keystroke "actions" that I can get in most other programmes.
Brian
3544.14 In reply to 3544.13
Oops...I had you confused with the poster that started this thread. Please ignore my last couple of posts then...
- Dave Morrill
3544.15 In reply to 3544.13
"I really can not cope with all this script stuff I need just the simple access to --well-- Keystroke "actions" that I can get in most other programmes."
Brian, you don't have to be able to write scripts to set up keystrokes, but because MoI is so open-ended it doesn't have many keystrokes set up as standard. Although this means that you may have to do some setup work, you can make the keystroke actions anything that you like, which should make them much easier to remember.
Say you want your SaveAs keystroke to be the key 'a'. This is how to do it.
1) Click on the Options button in MoI.
2) Click on 'Shortcut keys'.
3) Click the 'Add' button. That will insert an empty row in the dialog box.
4) Enter the letter 'a' (without quote marks) in the Key field on the left of the empty row.
5) In the Command field on right enter 'SaveAs' (again without the quotes).
6) Hit the Close button and the dialog will save your changes and disappear.
Now if you hit the 'a' button you should get the Save as... dialog pop up.
In this way you can make MoI's keyboard shortcuts resemble whichever software you are most comfortable with.
As far as I can tell, the list of MoI's "native" commands is as follows (see below) so if you want to attach ArrayCircular to a particular keystroke combination, all you have to do is enter ArrayCircular in the dialog box as described above. For more complex commands you may need to use a script (just copy and paste one written by Michael) but for the sort of thing you mention standard commands should be fine and as you can see they are easy to add.
Dan
AddPoint
Align
Arc3pt
ArcCenter
ArcContinue
ArcTangent
ArrayCircular
ArrayCurve
ArrayDir
ArrayGem
ArrayGrid
Blend
BooleanDifference
BooleanIntersection
BooleanMerge
BooleanUnion
BoundingBox
BoundingBoxCenter
Box
Box3pts
BoxCenter
Chamfer
Circle
Circle3pt
CircleDiameter
CircleTangent
Cone
Conic
Copy
CopyClipboard
Curve
Cut
Cylinder
Delete
DoCurve
DoScale
EditOrientations
Ellipse
EllipseCorner
EllipseDiameter
ExplodeMove
Export
Extend
Extrude
Fillet
Flip
GetBoxExtrusion
GetCircle
GetCylinder
GetDistance
GetLine
GetObject
GetObjects
GetOrientation
GetPoint
GetPointOsnappedOnCurve
GetRect
GetRect3pt
GetRectRoundCorner
Helix
History
Import
ImportPart
IncrementalSave
Inset
InterpCurve
Intersect
Join
Line
Loft
Merge
Mirror
Move
Network
New
Offset
Open
OpenTemplate
Orient
OrientLineToLine
OrientViewToView
Paste
PastePart
PlanarSrf
Plane
Plane3pts
PlaneCenter
Point
Polygon
PolygonEdge
PolygonStar
Polyline
Project
RadiusDiameter
RailRevolve
Rebuild
Rect3pts
Rectangle
RectCenter
RectWidthHeight
Revolve
Rotate
RotateAxis
Save
SaveAs
Scale
Scale1D
Scale2D
ScaleInput
Separate
Shell
ShowPoints
ShrinkTrimmedSrf
Silhouette
SketchCurve
Sphere
Sweep
Text
Trim
WaitForDialogDone
3544.16 In reply to 3544.15
Hi Dave,
Oops, thread took a quick detour :) Still interested in your approach to dynamic reloading, but no stress, looks like you have a lot on your plate.
Mike
3544.17 In reply to 3544.16
Dan
Sorry, I think my message is being lost
I live in hope.
Brian
Show messages: All  1-6  7-17
