Newbie Problem Shell/Offset complex Geo
All  1-6  7-14
3543.7 In reply to 3543.4
Hi Rogurt, see here for an example of how to make a rounded edge without making a degenerate corner:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3473.3
3543.8 In reply to 3543.6
Hi Rogurt, also see this other post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1127.4
For a description and illustration of what a degenerate corner on a surface looks like.
When a surface has its own control point grid organized in this way it is easy for the surface to become self intersecting as shown there, and that basically creates a micro tiny fold in the surface and that means the surface normal (which is a key thing used in offsets) can flip around wildly in that little spot.
So rather than making a surface that has that kind of degenerate corner in it, it will be better for offset to have a larger surface that has its control points in a more regular grid pattern instead of having corners of the grid bunched or stretched, and then have a trim curve that cuts away the excess area of the surface.
You can have all kinds of complex trim curves on a surface without it affecting the surface normal, but if the surface's own control points are bunched up or folded back on themselves it is a no-go for offsetting that.
EDITED: 17 May 2010 by MICHAEL GIBSON
3543.9 In reply to 3543.8
Thank you all.
@Paolo I understand these 3 samples are edits displaying the development from left to right. I tried to offset/shell the left one by 0,2 - wont work.
@Michael I am using the V1 30 days trial. I havenĀ“t got a key so no v2 beta download.
EDITED: 18 May 2010 by ROGURT
3543.10 In reply to 3543.9
All right. Now I dumped the whole shell attempt and duplicated the object, scaled it and did a boole. Result looks fine and calculation is way faster than "shell". So on to the next question: how can I bevel the upper edges via "filet" since I havent got continuus edges/splines I could select...
Thanx for your patience with me so far :-)
3543.11 In reply to 3543.10
> I could select...
Hi Rogurt, I'm not exactly sure wehat you mean by not having "continuous edges" - surely you must have a set of edges that touch each other?
You can select multiple edges to be filleted, you don't only have to select a single edge at a time.
So for example here I've selected 3 different edges at the top of this object:
And then I ran Fillet to make this result:
Edges that are not smooth to one another will have "corner patches" added to them to connect them up.
One thing to be aware of though is that Fillet is also a sensitive command similar in several ways to Offset. In fact a part of the fillet calculation involves generating offset surfaces and intersecting them.
So if you have things like little folded areas or tight bends in your shapes, it is likely to cause a problem with fillet in a similar way it caused problems with offsets.
3543.12 In reply to 3543.11
I would also note that in a couple of his questions he is typing "0,2" as a value for his inputs (note the comma)
Is this a typo in the question or is this the value he is trying to fillet??? (It was the same value in the shell question....)
3543.13 In reply to 3543.12
Hi Burr, in some other countries (for example France), the decimal digit separator is the comma character and not the period character like you are used to.
So for example in some countries they write the number "two and a half" in decimal form like this: 2,5
When your regional settings in Windows are set to use the comma character as the decimal separator, then you can enter in values like that into MoI.
See here for more details than you would want to know ;)
http://en.wikipedia.org/wiki/Decimal_separator
EDITED: 18 May 2010 by MICHAEL GIBSON
3543.14 In reply to 3543.13
OIC. Thanks for clarification.
Show messages: All  1-6  7-14
