First fillet does not work
All  1-4  5-6
3508.5 In reply to 3508.4
Hi Michael, I'm glad that solved it.
It can be easier in some ways to work on solids, because then you can cut a solid object up with Boolean commands and the various pieces of the cutting objects will stick around in the result keeping it a solid.
So for example if you have that revolved type shape, before you cut a hole in it it can be nice to seal off the end of it to make it a solid - there is a Construct > Planar command that will seal off planar openings like that.
Here's an illustration where I have a solid cylinder base object, and then I use the Boolean Difference command to cut a hole in it with the rectangle curve - note that the result in this case leaves the side walls that were formed from the rectangle extending out without needing to fill in those areas as a separate step:
3508.6 In reply to 3508.4
Here's another example - say you want to carve off the end of a cylinder.
To do that you might draw a curve in a side view that is positioned to intersect it visually, like this:
If your cylinder is an open surface, it might look like this:
You can use Boolean Difference to cut that cylinder surface up using the curve as the cutting object, which will cut it into pieces like this:
Then if you delete the end piece you'll see that you still have an open surface:
However, if you have a solid cylinder that has the ends capped off, it would look like this:
When it's a solid the booleans know how to combine the pieces together to keep the result a solid, which can help to avoid trying to manually build the side wall pieces.
Show messages: All  1-4  5-6
