Create round text
All  1-7  8-15
3488.8 In reply to 3488.4
Hi PP,
> But, you're right, for this very specific work,
> I need a polygonal tool.
Yeah for some kinds of things the NURBS focus on generating something completely accurate can be a hinderance if you only want to render the shapes instead of actually physically construct them.
With text that you are just going to render, a polygon modeling program is generally set up to be more free to make messy structure in the model that doesn't really show up in the rendering though.
Here's an example from Xara3D with some text:
If you switch to wireframe view, you can see that the model is not quite exactly the same as that outside appearance, various pieces are overlapping and running through each other beneath the outer surface:
The filleting mechanism in a NURBS modeling program tries to avoid that kind of a thing and instead actually produce the full accurate model with all pieces trimmed up and the inside actually all hollow. But that's a much more difficult task.
Anyway, this is an area where a polygon modeler can have an easier time making this kind of stuff since their tools are not really focused on making physically accurate results so much.
3488.9 In reply to 3488.5
Xara3D does not seem to be able to export 3D model data instead of only 2D rendered images though?
3488.10 In reply to 3488.9
No, that's true it can't export 3d data. That's why I was pointing out that if all he was looking for was a pre-rendered picture of the text or a rotating lit animation then 2d might be an option. If he needed model data then Serif Impactplus (no longer produced - but exports to .x) or Ulead Cool 3D Production studio (no longer produced - but exports to 3ds or .x) would have been totally simple and perfect for automatic extrusion and bevelling. I wouldn't recommend something like Cool 3D production studio for modelling something complicated, but for automatic extrusion of items it's pretty hard to beat. It was like modeling for dummies (perfect for me) :) I will never get rid of my copy. It's fun and useful, and people still use it for DVD menu animations today.
3488.11 In reply to 3488.9
Hello
just wanna say, that VUE (i got 7 infinity) has a nice and easy to use 3d text editor, it can also handle eps and AI files.
you can choose presets or custom bevel profiles.
and there are cheap versions available (starting at 0:-))
and vue can export 3d geomtrie (the 0$ version not:-)
3488.12 In reply to 3488.11
Another reason why Carrara is such a good companion app to MoI!
Brian
Size: 109.2 KB, Downloaded: 76 times, Dimensions: 1024x640px
3488.13 In reply to 3488.1
I'm sorry for forgetting about Carrara, Brian. You're right that request was totally in Carrara's area of expertise. I just bought that Daz book about figures and avatars (just for the Carrara 6 and hexagon) just a bit ago too.
3488.14 In reply to 3488.13
Thank you so much to every one.
MoI is the best software, but it also as the best support and the best community.
I can't imagine big software company support, like autodesk, answering : "we tried the software xara3D" and give explanation about polygon and nurbs.
I tested Carrara text tool, which is very good, but haven't test "VUE" yet.
Thanks again to every one, I now just have to choose the best solution.
EDITED: 20 Apr 2010 by PP
Show messages: All  1-7  8-15
