MOI3D to Octane Render Tutorial
 1-11  12-31  32-51  52-71  72-90
3472.32
I cannot speak to the official road map of Octane Render,as I have no control of that aspect of the Octane Render product, but from personal experience, I can confirm that the situation is not resolved 100% that the smooth group options do not rectify the situation.
I have tremendous respect for Radiance for his vision and skill to bring Octane Render to market. That is one of the reasons that I became involved with the project. I also love rendering in Octane as it allows me to "see" more than I could with other render engines.
I am for the most part, able to export items from MOI and make beautiful renders in Octane. It works great for my purposes. I can export a cylinder created in Moi using the standard tools and it looks perfect in Octane Render.
I tried the cylinder that you provided, Michael, in Modo and Blender using the script you provide. Using the OBJ import script, it is faceted in Blender and smooth in Modo. So, obviously, the code in Blender is not importing it correctly either, even with the modified script. Obviously, Modo was fine as many have stated. I also tried exporting this Cylinder as an LWO and using the MOI with Normals lwo import script listed on the MOI3D Resources web page, and it too creates a faceted cylinder upon import. So, I understand that you created the cylinder to prove a point and we'll try to use it as a test case to get the normals correct when the time is right.
I completely understand that many people may want to jump on SimLab or other comparable render engine if they feel that Octane is not the perfect companion to MOI3D now. It is something that I would like to have researched and improved in Octane, but cannot state that it will in fact be resolved for the 1.0 release.
We will continue to supply demos for users to evaluate prior to purchase, so please feel free to check it out before any purchase is made to ensure that Octane Render meets expectations.
Thanks for your patience with this issue. I will report back as progress is made.
Sincerely:
Phil Beauchamp
Refractive Software
3472.33
Hi vodkamartini,
thanks for your kinds words ... I sometimes have my bad days too in fact ;)
Hi candide,
Well I don't have the original scene, I think Sam from the Octane forum made it. Anyway, it doesn't look right for that amount of polys.
I'll see if I can get it to make some comparaison.
Hi Michael, I've copy your message about the cylindre on the Octane forum, and also Jamie resume. Thanks for clear it up in a nice english.
Marc has posted the result in images, ... we will see how it turns.
Radiance is still speaking about smooth groups grgrgrrmmmpffffff ...
3472.34 In reply to 3472.33
I'm not an Octane user (sadly, as I don't have a suitable card) but the vertex normals thing is something that seems to affect a great many of the 3D apps out there.
I am creating a ship model for a customer and the original brief required a pretty tight poly count. In order to achieve the count I exported individual obj's from MoI with a view to texture mapping in a poly modeller, merging the parts and exporting again as one obj. You would not believe the number of apps which cant handle this and create ugly faceted smoothing. Almost *all* of the UV & modelling apps I tried ignore the vertex normals in the file and seem to apply their own (incorrect) smoothing. So I feel your pain. This situation has been traumatic and has cost me a ton of time to find a workaround and is no fault of MoI's.
I can count on one hand the apps which worked for me...
1. UVMapper Pro
2. Milkshape
3. 3dsMax Trial (which of course, I can't use commercially)
4. Modified Blender script by Michael (which has issues instead with materials being mis-assigned)
5. Simlab trial
6. Probably 3D Paint Brush (trial expired)
Milkshape has a frustrating 65k poly limit but produces a nicely shaded model... for $35.
Why I wonder, are so many of these otherwise excellent tools crippled in this way?
Mark
(Looking at the above, I seem to have 6 fingers on one hand!)
3472.35 In reply to 3472.32
Hi Phil, just some additional info on this one part:
Actually what happens there is the normals are loaded (as long as you had welding turned off), and are actually used in the 3D realtime view in Blender which will have a non-faceted cylinder in it - don't get confused with Gouraud shading artifacts which are a different realtime rendering thing.
But if you then try to render it with Blender's default render engine, the renderer apparently decides to ignore the vertex normals that are present in the model and instead calculates new ones (which will be greatly degraded for CAD data) just for the rendering.
I actually didn't realize there was this bad problem with the Blender render engine until just now. I don't know why it does that, it is really annoying. Please don't use it as a model of how vertex normals should be handled, it's really very messed up.
Here for example I've found a post of someone mentioning this same problem:
http://geheim.blender.org/forum/viewtopic.php?t=13141&view=next&sid=41ba63d8dcc1ad464905c435d109c552
If you use a different render engine in Blender than the default one, or probably if you export your model, those good normals can probably get used. Anthony who wrote that LWO importer was using the Sunflow renderer, which ended up using the good normals, here is his original post about it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=979.1
EDITED: 26 Apr 2010 by MICHAEL GIBSON
3472.36
Hi all
Just to say:
obj files from MoI to (direct import) Thea Render = perfect result.
From Rhino to Octane by Osiris
3472.38 In reply to 3472.37
Hi Pilou, those look cool! But if you examine it closely I think you can see some of the artifacts being discussed.
For example here it looks like a visible seam appearing in the shading:
And here it looks like a sudden jagged bounce in the reflection:
Those are the kinds of imperfections that would actually be gone if vertex normals were being handled properly. It kind of gives an appearance of bumps or creases in those areas when probably the actual NURBS model was actually silky smooth there.
It's really sad to have such great quality for many of the other aspects of the rendering, but have problems in what is actually a really basic area.
3472.39 In reply to 3472.38
sure :)
Here is another really simple test - this one just has 1 single polygon in it so I don't think it can get any more simple than this.
I made a curved surface that looked like this:
But then meshed it with a really coarse angle setting to make just one polygon from it. But the vertex normals on the corners of that polygon will still be angled off to the sides (along the NURBS surface normals there) to give it the same kind of shading as the curved surface instead of it looking like a flat plane, here is what the mesh looks like when saving out from MoI:
Here is what it looks like when loaded into Cinema4D - note that even though it is a single flat polygon it has a kind of curved shading to it due to the vertex normals pointing off at angles:
The file is attached here as SingleCurvedPolygon.obj , can someone please load that into Octane and post what a rendering of it looks like? Does it look like a totally flat plane or does it have a gradient on it that looks similar to the original curved surface?
3472.41 In reply to 3472.40
Hi Michael
Unfortunately as flat as a pancake. I sure though it will be solved in time. I think this issue must be high up on the priority list for Octane now.
Jamie
Size: 654.5 KB, Downloaded: 60 times, Dimensions: 1024x512px
3472.42 In reply to 3472.41
Hi Jamie, thanks for testing that.
So yeah, there is absolutely no indication of the actual vertex normals being used there for the shading whatsoever.
It's pretty obvious that only the face normal is being used to shade it.
That would probably be a good example to send over, since it is so simple with just 1 polygon in it.
Did you use any particular import options into Octane for that render? There is something like a "Use smooth groups" option, was that option enabled or disabled?
3472.43 In reply to 3472.42
I have posted it on the octane thread and pointed them to this thread as well. I tried all the options for using vertex normals, smoothing groups but the result was the same. I opened it in rhino and the vertex normals are visible. It really does seem octane is not reading them at all.
Hopefully they can get it worked out because the render quality and speed are great.
jamie
3472.44 In reply to 3472.40
How is this flat polygon supposed to be shaded curved ???
all supplied vertex normals point in the same direction.
o object1
g object1
v 0.00000000 -0.00000003 3.13267816
v 0.00000000 0.00000008 -11.46117186
v 33.88950663 0.00000008 -11.46117186
v 33.88950663 -0.00000003 3.13267816
vt 0.00000000 1.00000000
vt 0.00000000 0.00000000
vt 1.00000000 0.00000000
vt 1.00000000 1.00000000
vn 0.00000000 -0.70710678 -0.70710679
vn 0.00000000 -0.70710679 0.70710678
s 1
f 1/1/1 2/2/2 3/3/3 4/4/4
3472.45 In reply to 3472.44
I dont know how it works but see attached image one is the single poly michael provided the other is a flat poly. You can see the reflections are totally different. Also the other pic is the opengl viewport in rhino and it is showing the normal direction.
regards
Jamie
Size: 11.9 KB, Downloaded: 57 times, Dimensions: 818x270px
Size: 42.8 KB, Downloaded: 78 times, Dimensions: 969x576px
3472.46 In reply to 3472.44
Hi Radiance
I made a single flat poly in MoI. The vertex normals are totally different.
mtllib SingleflatPolygon.mtl
o object1
g object1
v 0.00000000 3.13267827 -0.00000008
v 0.00000000 -11.46117210 -0.00000008
v 33.88950729 -11.46117210 -0.00000008
v 33.88950729 3.13267827 -0.00000008
vn 0.00000000 0.00000000 1.00000000
s 1
usemtl Default
3472.47 In reply to 3472.44
Hi radiance,
>>all supplied vertex normals point in the same direction.<<
They do not.
Check the "-"(negative) in front (of only some)of the values.
3472.48
Thea Render:
3472.49
Hello,
I got the same result as ycarry in TheaRender. If Octane doesn't pan out I can always wait to get GPU capability in 1.3. That kind of stinks since the new GPU is on it's way and from the videos I think I'll like the OR GUI a little better then TR.
3472.50
Okay, that's very sad. This dude cant tell the difference between Vectors? Is Octane using absolute values or something?
And further to the point..if you're the new kid on the block and you're in "Beta", dont upset your testers when they find a bug that saves you from your customers finding it in Production. Just fix the bug and thank your testers for finding it.
3472.51 In reply to 3472.50
Nice, I've been banned from the customer Octane forum :P
[QUOTE]
I've decided to refund you're license after reading your posts on the moi3d forum.
i spent 2 days working on a smoothgroup implementation to get your welded superball model rendered,
and yet you post such disrespectfull things...
[QUOTE]
I spent 2 days of posting examples/test/rendering comparaison ... well lets turn the page.
Show messages:  1-11  12-31  32-51  52-71  72-90
