Boat building
 1-4  5-22
345.5 In reply to 345.4
Thank you so much! I knew it was me..~:?) I find 3d softwarereally intimidating - I've learned to use Sketchup - we bought it to redesign a barn... bt generally they're scary and math heavy. I'm happier modelling in the solid with plastic or wood! Moi is undoubtably the best thing to come down the (3d) road for an old duffer like me. I may actually get the hang of this!
Thanks again - not all forums are so tolerant of raw beginners.
Fraser
345.6 In reply to 345.5
:) Well, I suspect that if you had some documentation and tutorials to go through it would help out some! In the meantime since that stuff is not ready yet, I hope that some more descriptive posts like this can kind of fill the gap... So don't hesitate to ask questions when you get stuck.
Seeing the questions also helps me to understand what areas tend to cause problems and can give me ideas on how to make more progress on making things easier in the future!
You're certainly welcome! I am very interested in making 3D modeling that works well for raw beginners, in addition to experienced people.
It is kind of a difficult task because often times "easy" and "powerful and flexible" don't naturally mesh together too well. But with MoI I hope to be taking a step towards providing both, at least to certain levels.
However, having said that there is still a definite learning curve... Like for example what you ran into in this case. The learning curve kind of gets magnified if you want to do somewhat more complex curvy shapes, there tends to be more things that can go wrong with that stuff.
345.7 In reply to 345.6
"However, having said that there is still a definite learning curve... Like for example what you ran into in this case. The learning curve kind of gets magnified if you want to do somewhat more complex curvy shapes, there tends to be more things that can go wrong with that stuff."
Yessss, I tend to want to run before I can walk... However, the learning curve here is not so horrific! I managed a (slightly wobbly) hull, so I'm pretty chuffed.
Is there a way to turn off the lines, apart from picking them out one by one and hitting the hide button?
Fraser
345.8 In reply to 345.7
Hi Fraser,
After you've selected one line, just press CTRL-A (or the Select All button in the Select pane). This will select all the remaining lines (provided that all your surfaces are joined together...)
If the curves you want to hide are on different objects, you must select a curve on first object, then you can select other (full) objects and finally select curves on them.
By the way, Michael, is it normal (!) that if you have several non joined surfaces (or different objects) and that you select a curve on one of them and press CTRL-A, MoI will highlight all curves on the selected surface and all the other surfaces, not the curves ???
Maybe not a bug, but at least some "unexpected" behaviour...
EDITED: 27 Jan 2007 by SCHBEURD
345.9 In reply to 345.7
There are 2 different types of lines - what Schbeurd wrote above applies to "Edge curves", which are the lines that show up at the borders of a surface. These are sub-part of a solid/surface object.
But you can also have regular individual curve lines that you drew with the "Draw curve" tools. I think you may be asking about hiding these regular lines?
Sometimes it is easier to select the reverse pieces, then do Select/Invert to flip-flop the selection.
The other thing that can help instead of picking one-by-one is to do an area select - this is when you click out in empty space and the drag a rectangle around things, this allows you grab a bunch of objects in one go.
The area select works slightly differently depending on whether you drag it starting from the left towards the right, or right-to-left. If you go from left to right, it will show a solid rectangle and only things completely contained inside of it will be selected. If you go from right to left, it will show dashed and things that intersect the rectangle in any way (not just completely contained) will get targeted.
So some strategic use of the area select can speed things up - you can often get an area that will grab a bunch of curves but doesn't contain the whole surface/solid (using the left-to-right method).
345.10 In reply to 345.9
Has another shot at a hull, this is the result. Thanks! It ain't perfect, but now I know can do it. The second Jpeg is soething a bit more straight forward - a 32 pounder...
Best,
Fraser
345.11 In reply to 345.10
Fraser,
Having a go at the PT-109?
345.12 In reply to 345.11
Spinner,
Nope, when I figure out how to do things like torpedo cut outs, build an Oerlikon gun etc. It'll be a 1942 Vosper MTB...
I'm scratch building one in plastic at the mo.
Cheers,
Fraser
345.13 In reply to 345.12
Samples from a few different eras there.. :) That's great progress!
345.14 In reply to 345.8
Well, this was intentional so that Ctrl-A / Select all would behave equivalent to dragging an area selection around everything.
But I think that you're right - if you have an edge or face sub-object selection it is probably more expected that select all will only grab those other sub-objects instead of everything else in addition to that.
I have changed select all to behave like this for the next beta.
345.15 In reply to 345.14
Cool ! Thanks Michael. It seems there will be a lot of small changes in the next beta that will make life easier ! ;-)
345.16 In reply to 345.15
Yup, a bunch of little polishing here and there.
It's easier for me to quickly jump on things that don't add any new top-level UI. Stuff that adds UI to the top level makes me slow down and carefully consider it an awful lot.
Now I just need to fix this meshing bug, get selection undo working, and get back on track to work on editing background images so I can release a new beta.
345.17 In reply to 345.16
It would certainly make life easier if one could have seperate top, side and front background images to work to!
Fraser
345.18 In reply to 345.17
> Cheers
> Fraser
Hi Fraser, you can do this with the current Jan-18-2007 beta! Add in as many background images as you want - you can draw one in the top view, one in the side view, and one in the front view if you like.
This is available under View/Image - that will open up some controls in the upper-right and there is an "Add" button there, add in as many images as you want.
345.19 In reply to 345.12
Snap!
I'm building a 20mm for mine in modo and MoI currently.
Elco 80, Fairmile D and Vosper is my build order.
MoI is prooving invaluable with its easy importing to modo.
WTG, Michael!
345.20 In reply to 345.19
Great!
I started an Oerlikon in SketchUp but haven't gotten around to finishing it. I did manage a 73' hull in SketchUp, but it was a complete bastard to do! In fact to do my scratch built Vosper, I modelled the bridge in SketchUp and then laid it out flat in Xara (what an ace vector prog that is) and cut plastic from those drawings.
The results, so far, are here: http://www.frasers-art.com/models/m-index.htm Working in both worlds is really 'educational' You can check out the sections you've drawn, make sure they fair up before getting busy cutting etc. My next problem is going to be finding a rorgamme I can actually afford in my now unemployed state to map, texture and colour what I do!
Have you got your work posted somewhere?
Best,
Fraser
345.21 In reply to 345.20
Seems you have a very good handcraft style!
345.22 In reply to 345.21
Cheers, Frenchy!
F
Show messages:  1-4  5-22
