WIP - RN Bartolomeo Colleoni
All  1-9  10-14
3445.10 In reply to 3445.9
Fabulous ship choice David. Are you able to visit the Aurora for research? Are you able to show some progress shots?
The Battle of Cape Spada is not as well known to Australians as Sydney's loss at the hands of Kormoran. On paper it appears as if the Italian cruisers had a superior position. The destroyers operating with Sydney couldn't reach the Italians with their guns, leaving 16 6" guns on the Italian side with which to counter Sydney's 8 6" guns. I've come to believe though that in reality the Italians were at a considerable disadvantage. The Italian cruisers had been built as a response to the large French destroyers with the emphasis on speed at the expense of protection. These cruisers were barely armoured and very vulnerable. In addition they were unstable gun platforms with serious roll issues making fire control difficult. To top it all off getting the range was made difficult by shells of variable weight, variable charges and guns prone to jams. On the day the Italians attempted to use their speed advantage but Sydney's fire was accurate, even switching targets a number of times during the engagement and scoring hits on both the Italian ships with fatal results for Colleoni.
Regarding the sea surface, I believe that rendering ocean accurately is just about the hardest thing you can do in this hobby. My results are nothing more than many hours of experimentation with shader settings. I am still not happy with the look of it (particularly close to the camera). I have found that shaders which look OK on a flat plane often look awful on a wavy mesh (the mesh I'm using is the same one I created in trueSpace years ago). I'd also like to be able to animate my oceans but this is impossible at the moment. I envy those with plugins like dreamscape (and the Max to use it with).
What are you using for rendering? If it is Kerkythea I would be happy to share my test scene with you.
Mark
3445.11 In reply to 3445.10
Just prep work for adding plate and belt lines to Colleoni tonight.
Mark
Size: 50.2 KB, Downloaded: 72 times, Dimensions: 1160x684px
Size: 39.3 KB, Downloaded: 60 times, Dimensions: 1160x684px
Size: 67.9 KB, Downloaded: 109 times, Dimensions: 1160x684px
3445.12 In reply to 3445.11
Thanks for show your advances and techniques.
I hope to post my ship tomorrow or on weekend. I would like to share with you (and the forum, of course) the techniques used to model it.
I have learned a ton searching other posts from you and JPBWEB.
About the rendered, I rejected kerkythea because I didn´t get the results I wanted, but I must to recognized that the problem was mine, not the rendered (as obviously).
A time ago, I made this render but I am not happy with the result. Then, I´ve been trying with Luxrender....but I´d love to come back to kerkythea only for get a nice result :-)
BTW...last week I read that the team of kerkythea have developed Thea render. It´s not free but people says that it is a great rendered. (and now, I know why there weren´t newest versions of kerkythea)
3445.13 In reply to 3445.12
Hi David, really looking forward to your Aurora WIP. I will be very interested to see your hull method. Without JP's help (and Burr, Danny etc) I'd still have a segmented hull. Being able to form the hull sides in one piece makes adding plate lines and the like much easier.
I really like the model car. I'm not a render expert (perhaps others might like to offer some advice/suggestions) but to me the lighting on the desk is a bit bright. As this appears to be an indoor shot, perhaps your renderer has some built in light settings which you could tweak to create more natural indoor lighting. Also the render method you choose has a big impact on render output I find. In KT I often use "Progressive Path Tracing" which offers a good compromise between speed & quality.
The KT forum is a pretty quiet place these days. They have promised that some of the advances in Thea will trickle down to KT though. Time will tell.
Send me a PM if you would like my KT test scene. Try it the way I have it set up then just play with the settings to get it the way you want it.
Mark
3445.14 In reply to 3445.13
Plate extrusions done, scuttles (I *hate* doing scuttles!), anchors and odds and sods.
Mark
Size: 53.5 KB, Downloaded: 92 times, Dimensions: 1160x684px
Size: 57.2 KB, Downloaded: 95 times, Dimensions: 1160x684px
Show messages: All  1-9  10-14
