I found the reason for the confusion - it's the script for open rhino documents for meshing. I found the function AssignObjectNamesFromStyles();, set it as comment and it works now. Since I found no rhino script for layer keeping I can keep my object names.
Micha
// Set object names to be their Style name + unique number.
var objs = moi.geometryDatabase.getObjects();
var styles = moi.geometryDatabase.getObjectStyles();
for ( var i = 0; i < objs.length; ++i )
var obj = objs.item(i);
var name = styles.item(obj.styleIndex).name + '§' + i;
// Replace all spaces with underscore characters, since spaces don't work as
// object names in OBJ files.
obj.name = name.replace( /\s/g, '§' );
function Convert(FileName)
var gd = moi.geometryDatabase;
// Open the file, set 2nd param to true to suppress any save changes prompt.
gd.open( FileName, true );
moi.view.resetAll();
// Create the output file name by breaking off the file extension and adding 'obj'.
OBJFileName = FileName.substr( 0, FileName.lastIndexOf('.') + 1 ) + 'obj';
// Save out to the output file, passing the option to suppress the UI. You
// add other options separated by semi-colons with no spaces. These
// options are available for controlling the meshing:
// NoUI=true
// Angle=6.0
// Output=ngons | quads | triangles
// MaxLength=
// MaxLengthApplyTo=curved | planes | all
// MinLength=4
// AspectRatio=0.0
// Weld=true
// Display=shadedwithedges | shadednoedges | wireframe
// ExpandedDialog=false
gd.saveAs( OBJFileName, 'Angle=;MinLength=;MaxLength=;AspectRatio=;Weld=true;Output=quads');
// Let's clear out and suppress any save changes prompt again.
gd.fileNew( true );
Convert('d:\\Temp\\#moi.3dm');
moi.exit( true ); // Pass true to suppress save changes prompt.
Visualisation for Designer and Architects
| http://www.simulacrum.de |
