Any octane user ? Closed  Locked
 1-6  7-26  27-46  47-66  67-86  87-101
3386.27 In reply to 3386.26
Hi PaQ,
> But as expected, it doesn't change anything for Octane :P
Well, the artifacts are slightly more evenly arranged... :)
But yeah you probably don't want any artifacts at all, hmmm?
In a moment I will do an export of your filleted cube out of Rhino for you test with as well.
  More Options
3386.28 In reply to 3386.27
Hi PaQ,
Actually, I won't do that, because actually Rhino doesn't have any way to write a welded OBJ file, it can only write the structure as when MoI has welding disabled, which I think you said produces a pretty different result.
For welding problems, let's focus on the cube example. That example is pretty clear - cube from MoI = problem, cube from Modo = same problem...
Probably a different case for non-welded would be good, a simple shape that is supposed to be smooth but gets creases in Octane. What would be work for that, maybe just a cylinder in 4 segments?
  More Options
3386.29 In reply to 3386.25
\\re :Modo cube
So the whole trick is to explain that IF the normal vertex channel WAS actually correctly read by Octane, we should get a flat shaded cube, without any smooth group/edge split system.
... but that's something I allready tried to explain, without real succes ...
I don't know what to think about Radiance's normal test from blender, where he actually invert or move the normal manually before exporting the model.
The model is actally looking like a mess in Octane, inverted normal seems indeed inverted ... so somehow ... Octane is reading the vertex normal direction from the .obj file.
  More Options
3386.30 In reply to 3386.29
Hi PaQ,
Hmmm, well I guess maybe don't try to explain the actual cause since that is going nowhere, just give the facts?? Like:
Simple cube exported from MoI - doesn't work properly in Octane.
Simple cube exported from Modo - also doesn't work properly in Octane - this certainly proves it is not anything specific to MoI.
Same cube works properly in every single other renderer...
So that's a pretty significant bug, Octane should be able to render those cubes the same as other renderers are able to.
The cube OBJ files are nice and simple short files without much data in them so eventually he should be able to dig into them and figure out what is going wrong in Octane.
Hmmm, well it sounds like he is possibly reading them in but somehow only using them for frontface/backface type calculations and not actually for generating the pixel level shading.
That would be quite strange though, because the primary purpose of vertex normals is to be used for shading!
For welded data though, the cube examples seem to show that they are not actually being read in properly for cases where faces have a shared 3D vertex but individual "per-face" normals. In some cases if a program only has lists of data at the vertex level it can have difficulty dealing with per-face type data, that might be one structural problem area.
  More Options
3386.31 In reply to 3386.28
[Actually, I won't do that, because actually Rhino doesn't have any way to write a welded OBJ file, it can only write the structure as when MoI has welding disabled, which I think you said produces a pretty different result.
Probably a different case for non-welded would be good, a simple shape that is supposed to be smooth but gets creases in Octane. What would be work for that, maybe just a cylinder in 4 segments?]
I've allready post so many examples, with edge weld on, off, closup of surface discontinuity, reflection glitches ... giving the .obj, compared with modo (it's the only software I have at home to comparing stuffs).
And of course I allways give extreme exemple with super low mesh ... because it's where artefacts are visible.
It's also true that if I tesselate my model like a fool, I have probably more polys than rendered pixels, glitches are not visible anymore :O)
... but it doesn't mean that low res has to look like 'shit' (sorry it's starting to be a little bit late here :)).
So I know I'm picky on that point, hopefully other users seems to be also annoyed with this, and I'm sure Radiance want to please users as much as possible.
Maybe there is something I don't understand, maybe the smoothing group implementation will also fix the other problems ...
  More Options
3386.32 In reply to 3386.31
Hi PaQ,
> problems ...
Well, no it's not gonna unless by "smoothing groups" he actually means "using the vertex normals from the OBJ file to do the shading"...
Well, maybe Phil can use the cube example, that's a very simple example and it's always easier for someone to analyze simple cases.
I guess you may want to just avoid trying to use Octane with any CAD data until the most basic stuff like just getting a cube in works though.
Maybe tomorrow or whatever could you do one more test with the attached file?
That's an unwelded file (with one version from MoI and one version from Rhino), and if it shows a segmented looking result in Octane instead of a smooth looking cylinder, then that definitely shows that vertex normals are not being used for the shading. That's another very simple case that you would probably want to be working in Octane before it would really be suitable for rendering any CAD data.
  More Options
3386.33 In reply to 3386.32
Here's the output from Octane, with a simple diffuse material (with normal smoothing turned on or off). The black triangles is another problem Octane is currently having. Are the cylinders supposed to be completely smooth? I can see some larger segments on the sides, even with smoothing turned on
  More Options
3386.34 In reply to 3386.32
Is the relevant discussion over in the octane forum in a private thread for registered beta testers only or something? I couldn't find it when I searched.
Just going by what I've seen here, I agree with Michael's assertion that the vertex normals aren't being handled correctly. I don't like that example Radiance gave with the sphere from blender. It sounds like he just selected a few faces, flipped them, and exported. Seeing that the faces are messed up in Octane doesn't prove anything about how the vertex normals are being handled, since the winding order of the vertices in the face definitions would also have changed. Octane could very well still be just averaging face normals. I just can't see the usefulness in that example.
  More Options
3386.35 In reply to 3386.34
The thread is in the subforums for licensed Octane customers, yes. I'll ask to have it moved to the general area so that other folks can see it
  More Options
3386.36 In reply to 3386.33
Hi candide, thanks for testing that.
> turned on
Yeah, it should be completely smooth if it was shaded using the vertex normals that are stored in the file.
If you see any segments at all, it means that smoothing is being created from the polygon data (which is in separate pieces because it was saved with no welding out of MoI) instead of using the true cylinder normals that are in the OBJ file.
For example here is what it looks like imported into Cinema4D and rendered, note that there is no visible seam between any of the segments:
  More Options
3386.37 In reply to 3386.36
So Phil - a welded box and this unwelded segmented cylinder are both good very simple test cases for Octane.
It's really important for both of these simple cases (or at the very least the unwelded case) to work in order for CAD data to be handled well.
As best that I can tell, the problem is that the vertex normals in the OBJ file are not being used for doing the shading.
If they were, then the box would have flat looking faces instead of having improper smoothing applied there, and the cylinder would have smooth looking faces instead of having improper creasing applied in that case.
EDITED: 27 Mar 2010 by MICHAEL GIBSON
  More Options
3386.38
Thanks Michael and Paq for putting so much time into this issue. I've learned a lot from reading this and will forward it to Radiance.
  More Options
3386.39
I tried to compare a cube exported with Blender and one with MOI3D.
The Blender file is this:
# Blender3D v249 OBJ File:
# www.blender3d.org
mtllib Blender-Cube.mtl
v 1.000000 -1.000000 -1.000000
v 1.000000 -1.000000 1.000000
v -1.000000 -1.000000 1.000000
v -1.000000 -1.000000 -1.000000
v 1.000000 1.000000 -1.000000
v 1.000000 1.000000 1.000000
v -1.000000 1.000000 1.000000
v -1.000000 1.000000 -1.000000
vn 0.000000 0.000000 -1.000000
vn -1.000000 -0.000000 -0.000000
vn -0.000000 -0.000000 1.000000
vn -0.000001 0.000000 1.000000
vn 1.000000 -0.000000 0.000000
vn 1.000000 0.000000 0.000000
vn 0.000000 1.000000 -0.000000
vn -0.000000 -1.000000 0.000000
usemtl Material
s off
f 5//1 1//1 4//1
f 5//1 4//1 8//1
f 3//2 7//2 8//2
f 3//2 8//2 4//2
f 2//3 6//3 3//3
f 6//4 7//4 3//4
f 1//5 5//5 2//5
f 5//6 6//6 2//6
f 5//7 8//7 6//7
f 8//7 7//7 6//7
f 1//8 2//8 3//8
f 1//8 3//8 4//8
That's what I'd expect. Why is the MOI file containing 12 points and in duplicate?
mtllib MOI-Cube.mtl
o object1
g object1
v 1.00000000 0.00000000 0.00000000
v 0.00000000 0.00000000 0.00000000
v 0.00000000 0.00000000 -1.00000000
v 1.00000000 0.00000000 -1.00000000
v 1.00000000 1.00000000 0.00000000
v 0.00000000 1.00000000 0.00000000
v 0.00000000 1.00000000 -1.00000000
v 1.00000000 1.00000000 -1.00000000
vt 0.00000000 1.00000000
vt 0.00000000 0.00000000
vt 1.00000000 0.00000000
vt 1.00000000 1.00000000
vn 0.00000000 -1.00000000 0.00000000
vn 0.00000000 1.00000000 0.00000000
vn 0.00000000 0.00000000 1.00000000
vn -1.00000000 0.00000000 0.00000000
vn 0.00000000 0.00000000 -1.00000000
vn 1.00000000 0.00000000 0.00000000
s 1
usemtl Default
f 1/1/1 2/2/2 3/3/3 4/4/4
s 2
f 8/8/8 7/7/7 6/6/6 5/5/5
s 3
f 12/12/12 11/11/11 10/10/10 9/9/9
s 4
f 13/13/13 14/14/14 15/15/15 16/16/16
s 5
f 17/17/17 18/18/18 19/19/19 20/20/20
s 6
f 24/24/24 23/23/23 22/22/22 21/21/21
  More Options
3386.40 In reply to 3386.39
If you tell Moi to weld vertices for export, it will create 8 too
  More Options
3386.41 In reply to 3386.39
Hi Phil,
It's like Candide wrote above - turn on the "Weld vertices along edges" option in MoI and then you will get an 8 vertex cube with shared vertices between the faces.
That's exactly what the weld option in MoI controls - whether to generate shared points where surfaces meet, or whether to have individual points for each surface but that are stacked up on the same location in space.
If you enable weld then you should be able to create an 8 vertex cube that will have the problem shown above when rendered in Octane.
  More Options
3386.42 In reply to 3386.41
Here's an update. Radiance added Smooth Groups Support (not 100% finished yet) and it improved the situation greatly.
Here's a file that PAQ exported from MOI.
Without Smooth Groups.
With Smooth Groups.
Thanks for all the support Michael. I appreciate your insight and putting up with us as we work to make Octane Render a great tool for MOI users.
  More Options
3386.43 In reply to 3386.42
Hi Phil, that's nice to have some progress there!
But really smoothgroups is not the best solution - the best solution is to not try and do any kind of additional smoothing calculations or break angles or anything like that at all, and just use the vertex normals as provided in the OBJ file.
You're still going to see various artifacts if the accurate vertex normals are not used for shading, for example in your "with smooth groups" post above, there are some irregularities visible in this area here:
That is supposed to be a perfectly smooth sphere, and the vertex normals that are in the OBJ file come from that sphere.
But if you try to recreate the vertex normals from the polygon data alone, _even with a smoothing groups mechanism enabled_ (!!!) you won't get as good of a result as just using the normals that are stored in the file.
I don't really know how I could explain it in any better ways than above in this thread, did you see my prior simplified explanation about why smoothing groups should not have anything to do with rendering the output from MoI? That was here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3386.16
What about the cylinder case as posted above, does the new Octane smoothing groups mechanism solve that problem?
  More Options
3386.44 In reply to 3386.42
Hi Phil,
It's still completely amazing that Radiance is trying to resolve this shading issues using smoothing groups.
It doesn't make any sence ... it's like importing the object in 3dsmax, remove the vertex normal map, and
using the smoothing group system to rebuild the normal and the sharp edges. That will NEVER match the accuracy and
the shading look from the original .obj with proper vertex normal.
This is how it looks in modo, without any smooth group, nor edge split.
Now, the smoothing goup system is super cool for poly software, it's definitively a nice feature ... it will enhance MoI (or cad)
models a lot, but will never come close to other render engine solution like C4D, Modo, LW, Maya Max etc.
Well it's just a non progammer advice :P
EDITED: 3 Dec 2015 by PAQ
  More Options
3386.45 In reply to 3386.43
Hi Phil, any irregularites in the vertex normals will especially show up in areas with specular highlights in them or with reflective materials.
You really want to just be using those normals for shading instead of calculating anything by smoothing groups at all.
Here's a comparison from loading that exact same OBJ file into Cinema4D, which does utilize the vertex normals stored in the file for shading - as you can see it gives a "perfect" result - every area is shaded exactly the same as the original NURBS data, that's the kind of high quality that you get if using the stored vertex normals :
  More Options
3386.46 In reply to 3386.45
Hi guys,
Those images are from a work in progress, the smooth group implementation is not finished.
People don't seem to understand things so i'll clarify them:
* I am not re-calculating vertex normals in octane, if they are present in the OBJ file, they are read and used directly for rendering. they are not modified or re-created by an averaging process.
* the images posted by philbo are not %100 in that the groups are used, but the correct splitpoints are not calculated yet. a vertex that is shared by 2 groups is currently set to the face normal, which gives the remaining facetting you see in the smoothgroup render. I'm still developing it and i need to write the code that handle these situations.
So just a bit of patience and when i'm done i'm sure it will look %100.
Phil posted those images a bit pre-maturely here, they are work in progress and clearly show that smoothing groups are the solution to the issue.
Radiance
  More Options
Show messages:  1-6  7-26  27-46  47-66  67-86  87-101
