Mobile Phone Problem ....
All  1-6  7-13
3366.7 In reply to 3366.6
Actually I kindof did it with your original file, but mechanically I think it is slightly off. I used one of the curved surfaces of the slider area and projected a line onto it. The I created a circle from 3 points with that projected curve to re-create the arc needed. Here is the file that "looks" like it slides, though I think to be exact, you should do this an keep the original cutting arc in place to use as the center of rotation to have it be proper!
Anyway, maybe this gives a better idea.
3366.8 In reply to 3366.7
>>>>I can't figure out how to make the slider part have at the same time a curved base and still slide horizontally ... >>>
They dont slide horizontally, they actually are sliding on the arc of the curved base. Which is a very large arc, so appears flat in your hand.
3366.9 In reply to 3366.8
Visual
EDITED: 5 Mar 2010 by BURRMAN
3366.10 In reply to 3366.9
Yupp, it works :) But what would you do when the base is actually flat but the plastic around it has a curve to it. Probably the widest point of the slider has to determine how wide the top of the phone is ... so they don't intersect
3366.11 In reply to 3366.10
I would imagine that in "closed position", the mechanism actually slips "down" a bit (the clcik you would feel when closing it) and then when opening it, the slider mechanism actually jumps "up" a bit (half of the radius value of the fillet on the top pieces underside edge) and then tracks along the slide.
Maybe I dont actually follow what your describing? If you post 2 sample objects configured like this I would love to look with you.
3366.12 In reply to 3366.11
Well ok I got the slider sliding ...
There seems to be a boolean difference bug ... when I subtract those 3 spacers from the buttons one button will dissapear ...
3366.13 In reply to 3366.12
Hi s7r83dg3,
> will dissapear ...
It can be normal to get that kind of behavior if the objects that you are trying to boolean are only open surfaces instead of closed solids, like they are in your case here.
Note that when you select this object here, the object type readout displays it as a "Joined srf" and not a "Solid" :
The booleans normally use the different volumes within a solid to determine which pieces to keep and which pieces to discard. If you have open surfaces then there are no volumes and they results will not tend to be as predictable with the booleans.
When working with open surfaces, you'll generally need to use the Edit > Trim function to cut pieces with one another and manually select which fragments you want to discard instead of using the Booleans.
Either that, or if you want to work with the Booleans make sure your objects are finished and closed solids and not just open surfaces.
Show messages: All  1-6  7-13
