Mesh - Matching resolution along edges
All  1-15  16-17
3365.16 In reply to 3365.12
It's an old workaround used in Rhino to force tesselation where the mesher doesn't find the solution on it's own. So yes, I mean you can try splitting the object then rejoing to make "user-defined" polygonal boundaries...
3365.17
Hi there
T-Splines can sometimes produce the kind of UV continuity you are looking for, but then again that requires Rhino + T-Splines.
T-Splines currently does not use trimmed surfaces, but it places vertex points points into the same plane to give a smooth result.
Think you may find this interesting.
-Fredrik
Size: 109.6 KB, Downloaded: 45 times, Dimensions: 333x266px
Show messages: All  1-15  16-17
