Boolean subteact ...
3363.1
How to subtract 1 from 2 in this case... ???
3363.2 In reply to 3363.1
may i´m wrong, but you can use your earlier created curves to get what you want?
look at the pictures
best regards,
tijai
3363.3 In reply to 3363.2
Not quite ... look at those spokes a little closer, they have a ridge on the back ...
Oh I guess those shapes don't line up correctly ...
EDITED: 3 Mar 2010 by S7R83DG3
3363.4 In reply to 3363.3
Ah, ok...
i try it again... with a little "dirty" trick.... I extrude the faces of object 1... so i can substract it from object 2...
(some boolean won´t do it ... i mirror the object... than the boolean works?)
whatever... is that what you wanna get?
best regards, tijai
Size: 79.5 KB, Downloaded: 59 times, Dimensions: 960x585px
3363.5 In reply to 3363.4
yeah thats it ;) but I think I'm on the wrong track ... I was trying to get this kind of rim
but the filleting operation doesn't work ... will try something else ...
Size: 287.4 KB, Downloaded: 34 times, Dimensions: 1227x1181px
