I tried using the new inset command, but to keep his original curve and the inset at the same size, I offset his trimming curve by the inset distance I was going to use. But the resulting inset didnt match the original curve, so I did the shell as jamie did. But, in the future, the new inset command can make shorter easier work of this without trying to reverse engineer the curve to work with that method.
