Hard to do for me
All  1-7  8-10
3349.8 In reply to 3349.6
>In some more complex cases that can be good to model the solid pieces as a 1/6 part, but if it is possible to have a single larger piece that then gets cut up that tends to be quicker.
I did 1/4 solid part.. but no success when I tried Boolean ... I did only without the secondary part joined with boolean .. when all merged with no fillets I could not do the booleans..
sry my english
3349.9 In reply to 3349.7
Perfect, I will try now.
>If you run into difficulties, try to post your current model that you're working on - 3DM format is actually the best format to save it in while you are in the middle of working on it, only use .STP format if you need to export to a different CAD system.
ok sry..next time I go to Moi before send the file... I save my work in 3dm always.. but MoI to viacad and vice versa the best for me is step..thats why I sent step file.. I discovered viacad in one post that u did.. and I use it for some bruteforce booleans and fillets.. it help noobs do thinks when cant get the right way I think.
Tharso
3349.10 In reply to 3349.9
Hi Tharso, no problem - I just wasn't sure if you were saving it in .stp for your regular work while inside of MoI.
Show messages: All  1-7  8-10
