V2 beta Feb-21-2010 available now
 1-8  9-28  29-48  49-57
3338.49
this last beta is not only fast and stable here, but the inset command is big fun to create detail - Superb!
One question: I model a lot in polymodelers and there if I would do a similar action to an inset on - for instance - three connected sides of a cube, the resulting inner polygons would stay selected, so I could repeat the action very fast and easily.
In MoI at this moment, if I want to repeat the inset 5 times for repetitive structures, I have to reselect the "polys"/patches each time which means first selecting the object again, then hit one face (and not an edge accidentally) to get to face mode and then select the other faces. So even in "repeat" mode, this is pretty slow to do what otherwise would be hitting "done" 5 times in a row.
Am I missing something here and it's already doable or would it be possible to have a "keep resulting faces selected" option?
Thank you very much for all your fantastic work!
Thomas Helzle
3338.50
Interesting thing is how you come up with ideas that are not found elsewhere, at least I have not seen exactly this before.
-FF
3338.51 In reply to 3338.49
Hi Thomas,
Nope, you're not missing anything - currently to apply another inset on the same area again, you will need to make a new selection. If edges are getting in your way frequently when you're trying to do face selections, try to zoom in a bit and also turning off the hidden line display can help a lot for that, there is a checkbox for that in the View palette on the side pane.
re: "keep resulting faces selected" option - well I kind of hate to add in too many options to things, it tends to lead to a clogged up type feeling in the UI and makes it harder to browse through the main stuff.
I don't think there are any other commands that select sub-objects in their generated result, so it may be a bit tricky to add that in. If it were to do it by default, it could possibly cause some unwanted side effects, like possibly the workflow for this example here would become kind of different with deselections needed first:
So I'm not sure, I'd need to think about that for a bit.
3338.52 In reply to 3338.51
Sure, let's finalise V2 first :) so you can start to work on V3 asap :)
3338.53 In reply to 3338.51
yes, I fully understand.
Actually, this is the first modeling tool in MoI that made me go to repeat immediately over and over again :-)
So for the first time I really noticed this difference to poly modeling and thought I bring it up in case there would be a good solution.
But no worries, I'm happy with whatever you come up with :-)
Cheers,
Thomas
3338.54 In reply to 3338.53
Hi Thomas, I tried a couple of ideas for keeping the face selection but since it is not similar to how other things work it does not look easy to do right now.
One idea I had was to maybe keep the face selection if you had turned repeat mode on by checking that "Repeat" button... That would avoid needing to add in any additional UI for this.
But that would mean having a command alter its behavior depending on what the repeat mode is and the current infrastructure is not set up for that.
3338.55
very great tool.. could be possible to have newly created faces with the same style of the mother.. or with the current active style
thanks and bye
3338.56 In reply to 3338.55
Hi taleequale,
Actually the way it currently works is that it inherits the styles from the original faces.
But the inset piece will be made up of a combination of pieces that come from the inset face as well as the side surrounding faces.
The various pieces of the inset will inherit the style of the original face that was used to produce the offset surface.
So for instance here is a box with a red top and blue side wall pieces:
When doing an inset of this, the inset will be composed of a red piece that was derived from the original top, and also blue pieces for the side walls, since those side walls of the inset are derived from the side walls of the original box:
Do you mean that you wish that the side walls were actually not inherited from their original source surfaces and instead made the same as the face being inset?
I'm not really sure if that would be possible for all cases, here is an example where there are multiple faces with different styles on them being inset, what would you want the side walls to come out as:
So note there that there is not necessarily a separate "side wall" surface for every separate face being inset, there are areas where there can be one side wall shared between multiple faces.
But the current method that makes the styles directly inherited from their originating surface makes this all work in a more predictable way...
3338.57 In reply to 3338.56
This should make the panel line issues I was dealing with a while back much easier. I've found ways to get good panel lines, but I'll have to try this new version and see if I can get quicker results with the inset commands.
Thanks Michael!
Show messages:  1-8  9-28  29-48  49-57
