projected curves do not cap when extruded
All  1-2  3-7
3318.3 In reply to 3318.1
Hi niko, also one other note - Trim actually has a projection method built into it already so it is not necessary to do the projection as an extra step.
So for example you have this surface and this curve:
Select the surface, run Trim, and then select the curve as the cutting object. Then right-click or press Done to keep all the cut up pieces. That will leave you with this result:
Select that small face, and then run Extrude:
3318.4
I thought of something when looking at this post, this only works for a single face, I just tried the same as your example but a joined surface with a seam in the center and I thought it would of been simple enough for MoI to work out, Oh well, it doesn't really matter I was just curious to see what it would do.
3318.5 In reply to 3318.4
Hi Danny, yeah currently extrude for surfaces is limited to only work on a single unjoined surface.
I do want to update it in the future to work with a joined surface as well, but currently you have to separate such things into individual surfaces first, and then extrude them. You can do a batch select of them instead of extruding them one at a time though.
The worry I had about extruding a joined surface automatically was that you could pretty easily create some messed up shapes if you did something like selected a box and then tried to extrude the whole box in one single direction. That would create something with degenerate flattened sides.
That's the part that is kind of harder to work out - trying to automatically figure out which kinds of joined surfaces would be ok to extrude and which would not. Maybe I will just not worry about that, but that was the issue.
3318.6 In reply to 3318.5
No big deal Michael, I'm not worried about it either :)
3318.7
Thanx Michael for the explanation
Your method should suffice
Show messages: All  1-2  3-7
