MoI as "the Visio of 3D?" Rendering advice please
 1-11  12-31  32-45
3310.32 In reply to 3310.30
>Then the other unfortunate thing is that often times your reward at the end of all that effort
>of targeting beginners is that your software can be derided as a "toy"...
Sounds like the voice of bitter experience. But hey, leaves more of the market for you, right?
Dan
3310.33 In reply to 3310.30
Incidentally, I notice that when rendering MoI models in Keyshot they come out fine, but when using Kerkythea the model appears to have "fallen over" into a different plane. Do different modellers have different Z or Y directions? In something like a 2D Excel chart Y is always up, but in MoI we seem to have Z is up, X is left to right and Y is front/back depth. Is this normal in modellers or is MoI unusual?
Dan
3310.34 In reply to 3310.33
Yes, it varies sometimes so all the professional 3d programs I've seen allow you to change those settings on export. Also, I was still working on your question about 3d rendering because it's something that has always interested me. I've got a few renderers of the pro level even though I'm a hobbyist, but I always keep my eyes open for something I can recommend to a friend. I was just looking at pov-ray again after years. The renderer is still excellent but is only command-line. While looking for a front-end for it I discovered that Pose-ray still works well in windows xp. It is a kind of kludgey interface, but it does exactly what it says. You install it and pov-ray then point poseray to the pov-ray executable. It imports .3ds .pov and .obj well. I tested it out and the only thing I couldn't get was the ground plane and global illumination. It's an extremely simple setup. I really liked it. I'm going to look for other pov-ray front ends, and maybe I'll post a test here if I can get it working to my satisfaction.
P.S. Michael, that seems to have fixed the posting problem. It looks right so far. Thank you.
3310.35 In reply to 3310.33
Hi Dan , yeah different applications can use different axis directions for the "up" direction.
For exporting out of MoI to OBJ format, there is an option you can set to adjust this here:
If you flip that "Orientation" option to the other setting before you export to Kerkythea that should automatically rotate the object and solve the problem. Switch it back again when you want to export to Keyshot.
Historically, for both mathematics and most construction industries, the method MoI uses is more common - that's where X and Y have a 2D sense as in a blueprint laying flat on a tabletop, and then Z is the elevation or "up" direction.
But it is not unusual for programs that are focused on bitmap image generation rather than on actual physical construction to use a different layout with X and Y meaning 2D on the computer screen and Z going inwards to the screen.
In MoI v2 you can change the axis labels to something that you are more comfortable with if you want, by going to Options > View > Axis labels. That allows you to view and type in x,y,z coordinates referring to whichever axis directions you want for each one. This axis labels setting does not have any effect on import/export though, it just changes how coordinates are displayed in the UI and how x,y,z typed inputs are interpreted.
3310.36 In reply to 3310.20
Mine was in Carrara if of interest
Brian
Size: 266 KB, Downloaded: 39 times, Dimensions: 1024x640px
3310.37 In reply to 3310.36
Brian, what can I say?! Your lattice is a heck of a lot bigger than my lattice!
Did you effectively just copy and paste that together? In my smaller version I used copy en masse for the sticks but added the balls (atoms) by hand using copy later.
Dan
3310.38 In reply to 3310.35
Thank you Michael, that worked very well for exports to Kerkythea.
Dan
3310.39
Hi Dan,
Although not exactly what you're after as a "Render program", figured I'd do a very quick render for you using my V-Ray for Rhino.
The model I've used is the one that BurrMan had posted earlier on within this thread.
regards Colin
3310.40 In reply to 3310.39
Dan
I used a lot of arrays/revolves etc!
After, first, a lot of mind twisting exercises and experiments!
A very mind broadening experiment!
Brian
ps--please!---dont ask me to repeat it!!!!! (I was so surprised when a result worked so much that I forgot what I did in detail!)
3310.41
Just couldn't resist putting in my 2 cents on alternative means of constructing some of the geometry in this thread using MoI.
Here's a version of a lattice created procedurally:
And here is the MoI script used to generate it:
Although it might be a bit of a challenge to create such as script initially, the advantage is that it is very easy to tweak things once you have it working. Here are two more variations of the original, with the only difference being that the first line of the script was changed to "n = 13;" and "n = 25;" respectively:
This particular script also has support for changing the radius of each sphere type, the radius of the connecting rods, the distance between the lattice points, and the style colors for each of the different elements, in addition to the overall size of the lattice.
BTW, for the n = 25 case, it took about 13 seconds to run the script to create the lattice. But at this point we are definitely getting outside of MoI's normal "comfort zone". Zooming and rotating the model to take the screen shot was initially extremely sluggish (nudge the mouse, then wait 3 or 4 seconds for the screen to update). I tried setting the Meshing angle to a much higher value and that seemed to help quite a bit. I could actually rotate and zoom the scene much more normally...
- Dave Morrill
3310.42 In reply to 3310.41
Sorry I don't remmember how launch this sort of script concretly?
With a normal shortcut? (put the text code in the second column? or inside another script ?)...
3310.43 In reply to 3310.42
Sorry, forgot to mention that the script uses an unreleased procedural library, so you can't run it at the moment. Maybe someday. It was meant more as an example of using the MoI programming API rather than something you could try yourself at home...
- Dave Morrill
3310.44 In reply to 3310.43
Michael, if you could just finalise the API Dave used, polish it to a high sheen, add a nice little front end, document the whole thing in detail and release in time the weekend, I'd be grateful.
Dan
3310.45
Dave!
I was wondering about the procedural script just the other day...
Release one :)
It'll be so handy!!
Show messages:  1-11  12-31  32-45
