solidThinking to modo workflow, help!
All  1-6  7-10
3299.7 In reply to 3299.6
> Anyway, it sounds like you have resolved your issue using the original model?
Absolutely, thanks again for your precious help.
Bye
Antonio
3299.8 In reply to 3299.6
Is the "Manifold Solid B-Rep Object Entity (Type 186)" in IGES not used? or is it a weaker implementation as in STEP? or does it not even describe the true solid?
3299.9 In reply to 3299.8
Hi Kevin,
Historically it is just not as common as individual surfaces.
I don't really know off the top of my head exactly how IGES entity 186 compares to object structures in STEP. But I kind of think they are generally similar in idea though.
IGES entity 186 I believe does describe a true solid.
3299.10 In reply to 3299.9
Great!
I love reading this forum, I've learnt so much from your excellent technical advise to situations all of us run into (shelling errors, fillet problems)
And the fact that this is software independent means the advise applies to many different modeling packages and situations.
So valuable!
Show messages: All  1-6  7-10
