Inset Command
 1-17  18-37  38-57  58-72
3295.18 In reply to 3295.17
> That was not yet possible with the offset shell function?
Shell is related but not the same - shell hollows out the entire object.
Like for example with this selection:
Shell hollows out the entire object and leaves those as openings, producing this result:
Shell produces a "thin wall" object.
An Inset on the other hand, does not go through the whole object and instead produces a result that is localized to those faces:
3295.19 In reply to 3295.18
Wow!
Great Michael.
eric
3295.20 In reply to 3295.15
Hi Burr,
> That looks very cool Michael. What happens on trimmed curved surfaces?
It can depend on the shape, there can be difficulties in the offset calculations in a lot of cases. Also currently the pieces being inset must be bounded on all sides by sharp corners.
But there are a lot of trimmed curved surfaces that will work as well, like here is a sweep that has a hole booleaned out from it:
3295.21
Woah!
Offset-shell-moveface combined!
Is this a special limited offer? Where do I order?
Marc
Effectively that is slighly different than the classical Shell :)
3295.23
Michael - that's awesome :D
Looks like you've managed to add the feature very quickly and very well!
3295.24 In reply to 3295.23
Hi NightCabbage, I'm sure that you will run into some cases where it will be frustrating that it won't work... The offsetting mechanism is not really at the same level of dependability as the boolean functions for example. It will help a lot to have very clean geometry, no things like little slivery bits or excess faces like 2 coplanar faces next to one another where there could instead be one large single plane.
But I believe it will still help you out in quite a lot of cases though. It should work well for changing a simple part into a more complex looking one extremely rapidly. Here's an example shape like you were asking about originally:
3295.25 In reply to 3295.20
Brilliant!!
I think this will certainly be a great addition for those of us making jewellery related items.
regards Colin
3295.26
Michael, really, thank you so much for this!
I'm not sure though, is this considered to be a "regular" bevel / extrude function?
I like how you can inset a surface, and it appears to let you also extrude in the opposite direction - I just want to be sure if you don't actually consider this an extrude or bevel function.
Either way, having this will make a snap of my panel work in a lot of cases! ;-)
-Will
PS - Okay, looking again at the GIFs, this is basically an inset/extrude since beveling lets you also change the width of the new face(s) - which is not what's happening here.
This is an awesome function though, can't wait to have this!
EDITED: 10 Feb 2010 by WILLBELLJR
3295.27 In reply to 3295.26
Hi Will,
Well, I'm not sure - what exactly would you expect for a "regular" bevel/extrude function to do?
If you would expect it to do this, then I guess this qualifies! :)
There will eventually be a different kind of extrude function called a "tapered extrude" which would make more like a conical type inward sloped extrusion from a flat outline. That one when starting from a circle curve would produce a cone shape. Is that the kind of thing that you're referring to?
Wait, I guess you're probably talking about something like this:
This new function will generate this:
But you're probably thinking of a polygon modeler type bevel which would be like this:
Maybe in the future that could become an option, like a "Tapered" checkbox to this same command - the pieces are kind of in place there you just need to have some Lofts put in between the correct edges. I don't think it will be very easy to incorporate that right now though.
3295.28 In reply to 3295.26
Hi Will,
Well, this will let you control the "border thickness" for how much the face shrinks inwards from its trim boundaries.
Then I think there will be an option to set the "Height" separately from the thickness if you want.
Then there is an additional option for Direction: Inwards or Direction: Outwards.
3295.29 In reply to 3295.26
Hi Will, just as a note - normally in CAD a bevel like this:
Is produced by doing a chamfer that cuts it away from a larger piece, like so:
Here's showing the original box in wireframe to help illustrate:
Rather than starting with the small piece and having it pop outwards from it like you would do in a polygon modeling program.
But probably in the future the Inset command could allow for that kind of "outwards growing" bevel as an alternate way.
3295.30 In reply to 3295.28
I wish there was the ability to record your thoughts as you iterate through these things! Perhaps you should record yourself talking through it for your little guy and posterity!!!
3295.31
Yes, Michael, that's what I consider a bevel, you can extrude out PLUS also vary the size of the new face (typically smaller but at times, you can make it larger or bevel out as well.)
But sans bevel, this new functionality is exactly what I was wishing for the other day and again, I appreciate the development time you've put into it!
I called it "regular" because these are the typical (should say required) functions that polygon modelers provide.
Nice to see it within MoI now also!
-Will
3295.32 In reply to 3295.31
Hi Will,
> bevel out as well.)
Actually the way I have it set up I should be able to make it go larger as well, as an option when Direction: Outwards is active.
I just tried it, and with the current non-beveling way it kind of puts "hats" on things:
Kind of crazy... kind of like "Add cladding" when it covers a wider area.
3295.33 In reply to 3295.31
The "hat mode" will probably be a bit less dependable even yet on wavy surfaces, but it's pretty interesting in several cases as well:
3295.34
This is great Michael :)
3295.35 In reply to 3295.33
This new feature looking very nice and fast.
But any body have an example of pictures when this feature will be very good in real design work ?
3295.36 In reply to 3295.35
3295.37 In reply to 3295.35
Hi Anis,
Just use your imagination! Design does not always have to be about reproducing exact copies of what already exists...
If you want to incorporate some inset or raised panels into your design this is one way you can do it really quickly.
But here's one simple example - a table:
Here's a table for holding sand:
Certainly there are other ways you can create such things, draw in a new curve, extrude it and boolean it, but with this new command it only took me literally a couple of seconds to do it. So for example with it only taking seconds you could be free to say - hmm, I wonder what this design would look like if this piece kind of punched out a bit, let's just give that a quick shot here (if it works... ;) and see what it looks like...
EDITED: 11 Feb 2010 by MICHAEL GIBSON
Show messages:  1-17  18-37  38-57  58-72
