Chamfer not working
All  1-4  5-11
3292.5 In reply to 3292.4
Hi NightCabbage, it kind of looks like you may be making those surfaces sort of one at a time and drawing curves for each surface individually and just kind of eyeballing the curves to try and make them similar to one another.
That's not going to produce enough accuracy to join things together - instead of making an individual curve for each surface that you want to create, you've got to share more of the curve structure between pieces.
Like for example do not draw in 2 separate curves for this area here:
Instead of having drawn in 2 separate curves there, you want to have just one curve drawn there and then use that same curve in the construction of both surfaces coming off of it, that way the surfaces will be close enough to one another to be joined together and have a common edge.
If you just create a bunch of surfaces that are somewhat visually close to one another but actually come from totally different curves the surfaces generated from those different curves will not necessarily be close enough to each other to be joined.
Edges must be within 0.005 units of each other to be joined together into a single common edge. It's easy for things to be further apart than that if you are just drawing visually similar curves instead of using the same curves directly.
You can also do things like use the edges of an existing surface as the curve inputs to commands like Network or Sweep, that's another way of making sure that the generated surfaces are going to be within tolerance of the existing ones. Using edges in that way can be handy if you don't happen to have the original construction curves around anymore.
3292.6 In reply to 3292.1
Hi NightCabbage - here's a bit of an illustration on how that area can be repaired by building a surface that touches the others with better accuracy.
To start with, I duplicated this edge at the bottom, by selecting it and then doing Copy and then Paste:
Now select the inaccurate face here and just delete it:
Now to make a better surface there, select these 4 curves - note that 3 of them are edges of the other surfaces:
And then run Construct > Network to build a surface from them. The generated surface will be within a good tolerance of those existing edges, so you can then select those surfaces and use Edit > Join to glue them together and get a proper single joined edge in that spot.
Once you have that set up, you can then select that edge:
And then Chamfer will work on it since it is a good single joined edge instead of it being 2 unattached edges with a gap between them:
That's the kind of sequence that can be used to repair something like this that has some pieces that are unjoinable because they are too far apart.
3292.7
:D
Thanks so much for the info!
I'm learning a lot!
I'm not sure how I managed to create extra egdes - oops! I'll have to keep an eye out for that sort of thing...
Also, it's going to be a hover tank - I'll post it, along with some others, after I've done a bit more work on them :P
(they only need to be simple, as they're going to be very small in my game)
3292.8 In reply to 3292.7
Hi NightCabbage,
It's hard to say exactly how that happened without watching the steps you used...
But it kind of looks like you may be drawing in some separate curves for different surfaces rather than building them all off of a single shared curve framework.
There some other kinds of ways that could happen too though, like using a surfacing command that did not make use of some curves, like a one-rail sweep instead of two-rail sweep or network... possibly something like that anyway.
3292.9
Ok, I've come across a problem, and I'm not sure what's causing it...
See the hole / overlap of the surface on the curves?
Why is it doing this?
(it's a network on some curves)
Trimming problem?
3292.10 In reply to 3292.9
Hi NightCabbage - actually there is nothing wrong there at all, that's just a display artifact from getting a coarse display mesh in that area.
That can tend to happen in areas that are pretty shallowly curved - not quite enough triangles got added into that spot.
That is something I want to tune up in the future, but for now the solution is to just treat it as a side effect of the display and ignore it.
If you see a more chaotic appearance in areas like that, like with maybe some dark streaks, then that is something to be more worried about.
When you go to export, you will have a chance with the export mesher to get more polygons in those areas if you want by using the "Divide larger than" setting.
The display mesher is more oriented towards doing things very quickly and in some situations it takes some shortcuts which can have a slight visual side effect like you have run into here.
3292.11
Oh, good! I was hoping it was something like that :)
Show messages: All  1-4  5-11
