Problem with 2 commands...
All  1-16  17-19
327.17 In reply to 327.16
Hi JTB - yes, the other person that contacted me through e-mail also had this problem only start with the Dec-24 beta, which had the changes in it to support different languages.
Can you please try the IE7 reset button as displayed here: http://blogs.msdn.com/ie/archive/2006/06/12/628499.aspx. It's in IE7 under Tools Menu, Internet Options, Advanced Tab, bottom of the dialog.
That way it will definitely rule out any problem with IE7.
If you try that and it still doesn't work then I will work with you on it some more.
327.18 In reply to 327.17
YES !!! Everything is OK now, Michael, thanks, nice to see it was so easy
327.19 In reply to 327.18
Great!! I'm glad that you are all fixed up now.
It seems that IE7 has introduced some kind of new setting or something that can interfere with MoI's scripting. If I can figure out which particular setting is the problem I can probably fix it up. But in the meantime I'm glad that reset button solves it.
Show messages: All  1-16  17-19
