Problem with 2 commands...
All  1-10  11-19
327.11 In reply to 327.9
What I suspect is that something went slightly wrong with your IE7 install and some stuff for scripting permissions was not set properly in the registry.
If you get a chance, could you please try re-installing IE7 again, and see if you get the problem again?
Thanks!
327.12 In reply to 327.11
Not sure if this info is of any use to you, but ArtCAM had a problem with IE7.
I'm not sure what it was, but they were advising everyone to un-install IE7 until they'd sorted it out.
I think that ArtCAM also uses HTML, so maybe their problem was similar?
Maybe something for you to look at??
Here's a link to the page with this info.
http://forum.artcam.com/viewtopic.php?t=2950&sid=d60c05a5fca64dd57ad138a48a63b91e
Hope this is of some help, Colin
327.13 In reply to 327.12
Thanks Colin! MoI doesn't normally have a problem with IE7, so under normal circumstances you shouldn't need to uninstall it.
However, it seems like there is a certain way that IE7 can possibly not get installed correctly - this is rare, but 3 people have reported it so far.
I think that there may be a common element with the AVG virus checker - possibly that virus checker interferes with the IE7 install.
327.14
I found a solution for my problem here:
http://blogs.msdn.com/ie/archive/2006/06/12/628499.aspx
A reset did the trick, and as I said I don't use IE as my browser.
Thanks for the ideas!!! :)
327.15 In reply to 327.14
Great! Thank you for reporting that back here, that's an easy solution.
When you get a chance later on, it would be cool to see some screenshots of what you're doing with MoI and trueSpace!
327.16 In reply to 327.2
Michael, both PCs have Panda Antivirus
Both PCs have IE7 installed before the DEC24 beta and it worked OK.
I think this is the first release that has a problem, that's why I don't think it is a problem of IE7
327.17 In reply to 327.16
Hi JTB - yes, the other person that contacted me through e-mail also had this problem only start with the Dec-24 beta, which had the changes in it to support different languages.
Can you please try the IE7 reset button as displayed here: http://blogs.msdn.com/ie/archive/2006/06/12/628499.aspx. It's in IE7 under Tools Menu, Internet Options, Advanced Tab, bottom of the dialog.
That way it will definitely rule out any problem with IE7.
If you try that and it still doesn't work then I will work with you on it some more.
327.18 In reply to 327.17
YES !!! Everything is OK now, Michael, thanks, nice to see it was so easy
327.19 In reply to 327.18
Great!! I'm glad that you are all fixed up now.
It seems that IE7 has introduced some kind of new setting or something that can interfere with MoI's scripting. If I can figure out which particular setting is the problem I can probably fix it up. But in the meantime I'm glad that reset button solves it.
Show messages: All  1-10  11-19
