Octane material ball made by MoI 3D
All  1-8  9-13
3265.9 In reply to 3265.6
"Boolean without intersecting surfaces? Is it possible? It should cause no geometry changes, only the bubble surface normals should be inverted and bubbles and sphere should be one polysurface. Are my thoughts right?"
Yeah I selected the sphere, then the bubbles, hit boolean by difference
And it was done :D
Amazing heh?
3265.10 In reply to 3265.8
Thx for that! :)
Now I must register :)
I have made publicity for your new French Forum ;)
See you soon!
3265.11 In reply to 3265.1
Hi DesuDeus, that's a cool render test model!
The renderings from Octane are looking great!
3265.12 In reply to 3265.6
Hi Micha,
Yes - in MoI you can boolean away an object that is completely contained inside of another with no intersecting surfaces, to make a solid that has an inner void cavity.
You may not be used to that since it is not possible to do that in Rhino.
You can also use Shell to create that kind of void cavity as well.
3265.13 In reply to 3265.12
Yes I used shell to do the ball, then I cut the Octane logo (the Octane logo is not a simple extrude, there's a scaling rail also)
Then I was able to boolean the bubbles :)
Amazing feature to be able to create watertight solids with void inside !
Show messages: All  1-8  9-13
