stl file
All  1-7  8-15
3261.8 In reply to 3261.7
Hi eric, I'm glad the patch solved the problem.
But yeah it is not very economical to rapid prototype something more than 1 foot tall.
Something more like 4 or 5 inches in size is more like it...
For something smaller like that, shapeways seems to have really good prices, even down to something like $20 or so which is pretty amazing (this kind of stuff used to cost several hundred dollars minimum). But the price must go up steeply once you get over a certain size.
3261.9 In reply to 3261.8
Hi Michael ..
Now that I can make things this way that work I'm full of ideas ... buildings take so long to reach the real end results (and often never do). I have always wanted to be a potter and see results immediately but my hands did not cooperate well enough. This 3d printing gives me another chance to use the tools of my trade to make small things with a lot of design possibilities.
Thanks again for MoI and the patch.
cheers,
eric
3261.10 In reply to 3261.8
The other thing to remember with them is they charge by "Volume of material used to print it", not size of bounding box. So if you make a simple sphere, it can cost alot more than if you boolean out the middle of the sphere and make it hollow. With the bounding box size, the only limit becomes what material you can print. At it's (the lamps) default 42 cm tall, their only machine and material is the stainless steel option at 1300+ dollars. To get the white stuff it has to be within a certain dimension (listed on their page). If you shrink your model down to be able to accept the white material, the price would go from 1300 to about 100. The transparent would be about 250-300. The price of the materials that reflect these numbers is $10 stainless steel, 1.50 white and 2.77 for the transparent.
Not very feasable for the lamp object though, But, if you wanted the transparent lamp shade, you could try and "Hollow out" the walls of the solid, then re-upload it in the dimensions allowed for that material and see how much the price drops. The hollow may make a nice effect if you can get the price to be around 50-75 bucks or so.
As for the unit conversion not working, I did have it set to scale on unit change also. But it sounds like Michael has found somethoing else going on there. It worked for me, but I was only using a P4 to do the file.
Anyway, Good luck.
3261.11 In reply to 3261.10
Hi Michael ...
I'm still having problems with this. I reduced the size and rebuilt the model ... after some fussing with booleans I finally had a solid and it did upload to shapeways after a failure and then increasing the number of polygons for export (by about 20%).
THe cost did came down substantially (but not enough) so I decided to scale it down further to the minimum size practical for its purpose.
I simply scaled it and sent it off ... got a 'manifold error'. So I tried again with increasing the export polygons ... still failed. The whole process seems pretty hit and miss.
I did have some trouble with booleans when I tried to run the cross supports all the way across and then build the pipe like cylinder and do a boolean difference to create an open channel. Finally had to use trim and then rebuild the cylinder back into a solid again.
here are the files ... maybe you can figure out why it fails.
thanks
eric
ps ... never mind ... I found a little closed curve that was still lurking there ... when removed the stl file went through just fine ... as an aside, it is still to expensive to be worth while for a small lampshade though it came down from $1600 to $340 just by making it 24% smaller overall.
EDITED: 23 Jan 2010 by ERICCLOUGH
3261.12
Hi Eric,
To reduce the cost of RP, I would suggest:
Size: 662.4 KB, Downloaded: 64 times, Dimensions: 1188x945px
3261.13 In reply to 3261.12
Hi Ralf-S ... thanks for the suggestion.
I'm not sure how this would reduce the cost ... I thought I understood that the cost applies to weight and material type, primarily.
I guess it also applies to the size of the printer required to do the job.
Am I missing something?
cheers,
eric
3261.14
Hi Eric,
Our RP service is calculated according to the used "space/box" and the material...
We have the information on the different "Space/box sizes" and
we can optimize our RP parts.
As application, we use (among others):
http://www.solidview.com/Products/SolidViewLite
3261.15 In reply to 3261.11
Hi eric, yeah I see you actually had 2 little extra surfaces in there that were separate objects from the lampshade but overlapping with it, and getting written to the same STL file.
Show messages: All  1-7  8-15
