New Jan-18-2007 beta available now
 1-18  19-38  39-58  59-60
325.59 In reply to 325.55
>Ideally this command would allow you to tell it
>either a number of control points or a tolerance
>value and it would create a new curve that followed the shape of the old one.
So multi-purpose command again and again...
I like this MoI's feature....and your programming approach that can be worded as "measure twice, cut once" as well.
Petr
325.60 In reply to 325.59
Hi Petr,
Yup, I've found that this is a really important goal. It's one of the things that makes a more streamlined (and along with that easier to use) UI - trying to get more use and "value" out of each little bit.
Thanks! Yup, I think that's pretty close. Similar to carpentry it helps to reduce different kinds of waste.
Show messages:  1-18  19-38  39-58  59-60
