New Jan-18-2007 beta available now
 1-5  6-25  26-45  46-60
325.46 In reply to 325.45
Thinking that possibility to add images was yet a big help in a session,
and as nobody speak about saving configuation
I was imagine the worst :)
For one time I had read well the news, it was not specified !)
Reality is sometime more strong than the imagination :D
EDITED: 22 Jan 2007 by PILOU
Tested the transparency of the Png format inside Moi :)
That works fine!
File Test is an object (yellow) mixed with 3 images png "transparent"
Some "plan" of image seems opaque for other following rotation on the axe "two by two"
You rotate all the view and the opaque plans became normaly transparent and other became opaque :)
Images Png used are "realy" transparent like helix4 (make your try)
Ps
Seems you have coll managed the names of files when the "same image" is loaded in the 3 views and Hide or Remove after:)
EDITED: 23 Jan 2007 by PILOU
325.48 In reply to 325.47
Hi Pilou, thanks for testing the images!
Yes, this would happen if the images were intersecting or pretty close to each other. I've improved it for the next beta so that fully transparent areas work better even when images are intersecting.
Thanks!
325.49 In reply to 325.1
Curious!
Each time you Double Click on the Icon Option (page Right Botton) there is an Alert Message
See the image :)
I have tested on the privious versions, that didn't arrive !
EDITED: 26 Jan 2007 by PILOU
325.50
Weel done Test Pilou! ;)
___________________________________
MrBraun - Moderator www.C4dHotline.it
Cinema4D R10 and MOI of course!
EDITED: 26 Jan 2007 by LORENZO
325.51 In reply to 325.49
Hi Pilou, thanks very much for finding these tricky bugs!
This one is now fixed for the next beta.
New french translation : more Zen :)
(version 27 01 2007)
Just
copying / Replace the attached FrenchStrings to the C:\Program Files\MoI beta Jan-18-2007\ui folder.
Have fun :)
325.53 In reply to 325.40
Michael wrote:
A NURBS circle is made up of 4 internal arc segments, although since they are fused together with a shared tangent, they will not automatically separate out with the regular "Separate" command. [...] I should be able to detect the segmentation and re-approximate that curve with a single smooth non-segmented piece within tolerance which will then behave better.
If I understand you well MoI is currently able to reduce and move a curve control points properly while maintaining general shape of curve? If Yes I think it would be good idea to write an interface for such command which could simplify a complex curves that originate as a result of using offset, trim (pseudo project/pull) or sketch commands and which are to be used for other modeling tools (extruding, sweeping...).
Petr
325.54
It appears that message has been overlooked... or you start working on it... hehe
Anyway, you can keep calm...I don't complain...
Petr
325.55 In reply to 325.53
Hi Petr, yes there are a couple of different techniques that I can use to do this.
For improving lofting it is a little trickier, since it has to be done in a synchronized way to a whole set of curves, not just one. For instance if one curve needs to have a point inserted, the other curves also need to insert that point so they stay synchronized and can more easily create a simple surface when they are combined through lofting.
Yup, this would be the rebuild command, several people have already requested it. It will definitely happen at some point but I'm not sure when yet. Ideally this command would allow you to tell it either a number of control points or a tolerance value and it would create a new curve that followed the shape of the old one.
A slightly different version of this is actually already happening in the Freeform/Sketch command - if you turn on control points of a sketched curve you should see that they are pretty sparse.
Seems you have not put the F11 as Full screen? :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=207.55
I have put it, that works always as a charm :)
325.57 In reply to 325.56
I'm a little bit worried about putting it in by default... If someone accidentally hit it there isn't anything available on the screen to get out of the full screen mode.
It probably needs to wait until it gets some UI on the screen to restore it before I can put it in by default.
But if you set it up yourself, it won't be a surprise...
325.58 In reply to 325.57
So it's not exist by defaut or not!
Only for happy few :)
325.59 In reply to 325.55
So multi-purpose command again and again...
I like this MoI's feature....and your programming approach that can be worded as "measure twice, cut once" as well.
Petr
325.60 In reply to 325.59
Hi Petr,
Yup, I've found that this is a really important goal. It's one of the things that makes a more streamlined (and along with that easier to use) UI - trying to get more use and "value" out of each little bit.
Thanks! Yup, I think that's pretty close. Similar to carpentry it helps to reduce different kinds of waste.
Show messages:  1-5  6-25  26-45  46-60
