Dimensions and printing
All  1-2  3-16
3232.3 In reply to 3232.2
Hi Michael ...
Well that's kind of good news ... at least it is on the radar ... a while back I was hoping some might be done in V2.
Grabbing screen shots with Snagit and then using the Snagit editor does a pretty good job for noting details that have to be shared with others.
It would be helpful to be able to print the image out to PDF.
You are doing a great job and I have never seen support like yours!
cheers,
eric
3232.4 In reply to 3232.3
Hi eric, yeah it would have been nice to have it in v2, but there are only so many hours in the day...
re: screen capture - instead of using SnagIt, you might be interested in setting up the following script on a keyboard shortcut in MoI:
script:var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; }
Go to Options > Shortcut keys, and set up a new shortcut key and paste in the above as the Command part for it.
Then when you press that key it will generate a higher resolution viewport image and copy it to the clipboard. If you then reduce that in size in an image editing program it can make for a nice effect.
3232.5 In reply to 3232.4
Thanks, Michael.
I'll try that tomorrow.
eric
3232.6 In reply to 3232.1
Hi eric,
I am also waiting for dimensioning in MoI :).
But today sometime I use Alibre DesignXpress and or Kompas LT.
Have you try it ?
Thanks !
3232.7 In reply to 3232.6
Hi Anis ...
I have Rhino and do all my 2D dimensioning with it (and some 3d also).
I purchased Alibre but have not actually used it yet.
cheers,
eric
3232.8 In reply to 3232.7
I use the free version of SketchUp for dimensioning my MoI modelling.
Ntian
3232.9 In reply to 3232.8
Hmm, and is there a way to put out a drawing, lets say, in M 1:20 ?
3232.10 In reply to 3232.9
Hi Janne,
Do you mean in SketchUp?
There do seem to be some controls in there for controlling the scale of the printout, but they will not be active with the default perspective view.
In SketchUp, go to the Camera menu, and set the "Parallel projection" option and also go to the Camera > Standard views submenu and choose one of those views in order to get the print scaling controls to be active.
if this can help :)
For the free version of google sketchup ;)
CLick image for zoom
EDITED: 10 Jan 2010 by PILOU
Size: 63.2 KB, Downloaded: 103 times, Dimensions: 481x815px
3232.12 In reply to 3232.11
Michael? Is Grouping system connect to dimension system as well ? thats the reason to will make basic dimension?
3232.13 In reply to 3232.12
Hi andras,
You mean in the future for MoI?
Grouping will be a way to organize your model into a hierarchy of containers... It will not really have much to do with dimensioning.
The reason why I say "basic" dimensions is that I probably won't have an extremely detailed level of control over the dimensions like supporting 5 different international standards of arrowhead symbols, or stuff like that which you may find in programs that are very focused on drafting.
The main goal will not really be to replace a dedicated drafting program, but just to be able to place some basic annotations for simple communication.
3232.14 In reply to 3232.13
just because I thought dimensions will be complex object by lines and text in a group...
3232.15 In reply to 3232.14
Hi andras, I see what you mean... That is true that a dimension is going to be some collection of lines and text within it. But there will be additional logic to control it and arrange these pieces that will not be very similar to groups.
So a dimension is probably going to be more like a special kind of object that will be added into MoI and not just something that comes automatically with a group function.
3232.16
Thanks Michael, Thanks Pilou, i will try that.
Show messages: All  1-2  3-16
