futher plans
All  1-4  5
3225.5 In reply to 3225.4
Hi Fredrik - yeah a clipping plane type mechanism is a little different than a section command though.
A section command would generate curves - see for example the Rhino "section" command rather than that Asuni plug-in.
But you should be able to get the exact same result as a section curve generation command with MoI's current Project command, just draw a line and use Project.
Show messages: All  1-4  5
