futher plans
All  1-2  3-5
3225.3 In reply to 3225.2
Well an hidden line removal would be the most importatn thing for 2D detailing that would be an key.
3225.4 In reply to 3225.2
Michael,
Section views can be useful both for presentation and to help understanding the shape one is working on.
Here is a this plug-in for Rhino, made by Asuni-Cad.
I think the way it can use a 3d clipping object for showing the internals objects to be intuitive and easy to use.
http://www.asuni.com/?category_name=labs
-Fredrik
3225.5 In reply to 3225.4
Hi Fredrik - yeah a clipping plane type mechanism is a little different than a section command though.
A section command would generate curves - see for example the Rhino "section" command rather than that Asuni plug-in.
But you should be able to get the exact same result as a section curve generation command with MoI's current Project command, just draw a line and use Project.
Show messages: All  1-2  3-5
