Remnants after boole cut is made.
All  1-5  6-9
3217.6 In reply to 3217.3
I just received your update.
That is interesting. When I created the thread profile I made it so the legs extended half way between the helix cycle so there would not be a gap. I will cut the profile legs back a bit. I will also scale up.
Thanks.
L.
3217.7 In reply to 3217.4
Hi Leonard, check out the attached model - it should now boolean for you properly and give you a clean cut.
I scaled it up by 10 times in size - you can scale it down again if you need to have the final model smaller, but really the key thing is that when I created the sweep I made sure it did not run over top of itself and had some clearance here:
3217.8 In reply to 3217.6
Hi Leonard,
> not be a gap.
That could be good if it was like 2 separate objects that were meeting up and then would be joined together.
But having a closed object kind of skim along its own self like that creates ambiguity in the intersection calculations.
3217.9 In reply to 3217.8
I enlarged everything 10X and adjusted the profile and presto!
Edit: Added pic of the clock. You can see the two screws on the front. The width is 8"+.
Thanks for the help, Michael.
L.
EDITED: 2 Jan 2010 by NYCL45
Size: 165.6 KB, Downloaded: 42 times, Dimensions: 810x712px
Size: 291.3 KB, Downloaded: 79 times, Dimensions: 1265x938px
Show messages: All  1-5  6-9
