Shortcuts for new hide functions
All  1  2-5
3213.2 In reply to 3213.1
Hi Tony, actually the same old Hide script should still work...
To get the same result on a keyboard shortcut as the left click on the Hide button, use the following for the command part:
script:moi.geometryDatabase.hide();
If you want to have one that is the same as the right-click on the Hide button for the Isolate function, then use this:
script:moi.geometryDatabase.isolate();
And if you want one that is the same as Ctrl+click on the Hide button for the "show subset" function (where it lets you pick just some of the hidden objects to show rather than showing all), use this:
script:moi.geometryDatabase.showSubset();
3213.3 In reply to 3213.2
Hi Michael
Thanks for that.
However, now that I've used it a bit, I must say I really don't like the new behavior very much. I now have 2 commands where 1 used to do the trick.
Is there any way the old behavior can be emulated in a script, please?
I really liked the way I could click on something and move it into the hidden 'holding area'. Then, with the same shortcut choose which things to bring back.
Tony
(aka HamSoles)
3213.4 In reply to 3213.3
Hi Tony, yeah unfortunately the old behavior where the show function was always "show subset" was just too confusing to too many people. I got too many questions like "why did the objects reverse and then reverse back again?", etc...
So that's why they were broken into some separate functions.
It is possible to get the old behavior with a keyboard shortcut script though, for that use the following:
script: /* hide selected objects, or show subset if no selection */ var gd = moi.geometryDatabase; if ( gd.getSelectedObjects().length != 0 ) { gd.hide(); } else { gd.showSubset(); }
3213.5 In reply to 3213.4
Thanks very much Michael. That's just what I was after.
I also found the old hide confusing for a while - but like all your new ideas it became very useful once I got used to it :)
With the new behavior I don't like how it unhides everything, so then I have to go back and hide a bunch of objects again. If you have a lot of hidden objects this can be a nuisance.
Thanks again.
Tony
(aka HamSoles)
Show messages: All  1  2-5
