Just an incorrect accuracy
All  1-2  3-4
3195.3 In reply to 3195.1
Hi andras, one other note - I do not recommend that you leave your display mesh angle set to a small angle value, because that will cause a slowdown and increased memory consumption.
The default is 10 degrees, and you should probably not set it any lower than that for regular use, unless you plan to only make some very simple objects only.
3195.4 In reply to 3195.3
Hello Michael!
Yes, I considered no problem. The Shape is ok all right ... anyway the new orient tool is fantastic and very useful I like that !
Show messages: All  1-2  3-4
