Greek Column.. how to?
All  1-3  4-15
3193.4 In reply to 3193.3
Hi Tony, can you please post an example model for something that is not welding for you?
If you have 2 solids sitting next to one another, rather than 2 individual surfaces then you would not use join for that because join is for gluing unattached edges of surfaces together. Solids have all edges already attached to something so you usually need to do a boolean union to combine solids rather than Join.
But the specifics depend a lot on what you have for your model - so it is a bit hard to give you a definitive answer without seeing your actual model.
3193.5 In reply to 3193.4
hi thanks for the quick response again, here is a breakdown of what ive done so far.
1. create a circle.
2. create a smaller circle on the outer edge of the first circle in step 1. and use a radial array to create the indent shapes for the flutes
3. boolean subtract to take the array away from the original circle in step 1. leaving a profile of the column
4. i then used join to join the profile pieces together
5. then on this shape i extrude to create the column.
this leaves me with a circular column with the flutes i need.
i then export this shape s .obj, with ngons as modo can cope with these but the poly's dont seem t be joined as in the final image.
hope this is a bit clearer, im using 19dec v2 beta
thanks again
Tony
3193.6 In reply to 3193.5
Hi Toni,
Please take a look:
Size: 131.3 KB, Downloaded: 96 times, Dimensions: 1046x751px
Size: 82.6 KB, Downloaded: 74 times, Dimensions: 717x665px
3193.7 In reply to 3193.6
hi Ralph,
thanks for the input..
is it the weld vertices along angle that may be the problem....??
how does this work..
thanks.. happy holidays...
ps. that how mine looks when i import into modo, i hav shown when i select a poly and then move that poly,
Ralph, if you enter polygon mode and select the end polygon, can you then move that polygon as i have shown as it is not welded,
or is it in your example?
3193.8 In reply to 3193.7
I made this in V1.
Hope you can get some value from the file.
Brian
3193.9 In reply to 3193.8
Hi Tony.
I have followed your instructions and imported the object into modo using default .obj export settings and can confirm that the column comes into modo as groups of polys(groups for outer edge, groups for flutes and one ngon each for top and bottom). If you wish to then make this one solid in modo you can just click on vertices tab, select all vertices and run the Merge tool. This will join all vertices existing in the same space(320 in my test) and leave you with a solid column(all polygons joined).
Malcolm
3193.10 In reply to 3193.7
Hi Tony, like Malcolm mentions you should be able to use the Merge tool inside of Modo to update the model to have welded points.
But it should also be possible to get that built in to the export from MoI - that is entirely what that "Weld vertices along edges" checkbox option inside of MoI's export options is for. When it is checked MoI will generate a welded mesh where polygons from different surfaces will share a single vertex in common between them. When it is unchecked each polygon will instead have their own individual vertices but stacked up on the same location.
It may be possible that Modo's OBJ importer decides on its own to break things up at different smoothing groups or something like that.
I'd recommend using LWO format instead of OBJ format for going into Modo. Previous versions of Modo did not handle n-gons very well in OBJ format, so really LWO has always been the best method for transfer to Modo.
I don't think that Modo messes around as much with the data it gets from LWO since it is closer to its native data arrangement than what is in OBJ.
I only have an old version of Modo here (203), but testing LWO format with it and your shape everything seems to be how you want it.
When I do the import into Modo it looks like this:
And then if I select a vertex and move it, I get this kind of a result:
Is that what you want to get?
Does using LWO format solve your problem?
3193.11 In reply to 3193.10
hi everyone,
just read this thread, thanks for all your replies.... will try again today with some different settings and see how it go's.
having to weld all vertices in modo could be a time consuming task depending on the.
ps just found my error... i didnt see the more option arrow on the export dialogue , weld vertices... that was my problem all along...
silly me.. must have been the christmas pudding.... too much brandy in it...
thanks again for all your help
3193.12
Hi Tony,
Yes, the "Weld vertices along edges" export option is the right choice.
Btw.:Could also be interesting. :)
http://www.guerrillacg.org/home/3d-polygon-modeling/multi-sided-polygons
EDITED: 26 Dec 2009 by RALF-S
3193.13 In reply to 3193.11
Hi Tony, that's great I'm glad you have solved the problem!
3193.14 In reply to 3193.13
yeah..!! theres a lot to learn even with this 'simple to use' program... thanks for all your help...
3193.15 In reply to 3193.14
A great side effect of this seemingly simple, yet very powerful program, is a gain in understanding how it all really "works".
Show messages: All  1-3  4-15
