boolean problem
All  1-16  17-18
3190.17 In reply to 3190.16
Hi Tree,
> Is the surface/surface intersection tolerance something that
> can be or will be able to be controlled by the user?
That's theoretically possible, but it's a rather arcane esoteric value for people to adjust, and it is easy to adjust it improperly if you do not fully understand what it is controlling.
Things tend to behave really strangely if it is too loose, you end up with kind of saggy intersections.
> In the cases where booleans do fail and no result is given or pieces
> just vanish, would it make sense to give the user control somehow
> to adjust how it performs the boolean?
Well, part of the update is that if it failed or if there are naked edges in the result when there were none in the inputs, it will repeat the boolean again with an automatically tightened tolerance. It will go through that cycle a few times.
3190.18
Almost looks like a PBW (Earthsiege / Starsiege) :)
http://www.angelfire.com/sd2/nightcabbage/Stuff/3dsmax/pbw2.jpg
EDITED: 2 Feb 2010 by NIGHTCABBAGE
Show messages: All  1-16  17-18
