New Beta
All  1-6  7-12
3176.7 In reply to 3176.6
Thanks Michael
I understand that last post (easy) but, trying to use your previous explanitory post seems to be beyond me---brrrhhh!
Am I miss interpreting what your meaning is of--"set up a blank model""??
Sorry!
Brian
3176.8 In reply to 3176.7
Blank in this context just means "no objects".
So set up your styles as you want, but do not create any objects - then save out as a 3DM file. The file will contain no objects but it will contain a style list still.
When you set it as a template, that file will be loaded as the starting environment when you start up MoI or pick File / New.
You can have objects in there as well, if you always want some particular objects to be included in your environment when you start up MoI each time, but usually most people don't want there to be any objects in their model when they initially start the program, hence the "blank" part.
3176.9 In reply to 3176.8
Brian
3176.10 In reply to 3176.9
Hi Brian, I'm still working on the release notes, won't have those ready until tomorrow.
3176.11 In reply to 3176.4
>Hi Brian
>re: set default styles - the way you do that is to set up a blank model with the styles how you want it, then save that >off to a 3DM file.
>Then go to Options > General > Template file: and specify that file as the startup template.
>Then when you start up MoI or do A File > New, that 3DM file will be used as a template and the styles (and objects if >you wish - anything that is stored on a per-file basis) will be sucked in from that file.
>- Michael
Thanks guys, I had been wondering how to do just this thing.
Mark
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
3176.12
Great stuff Michael G.! I noticed that you don't have to hold down the tab key while typing "merge" when merging edges. Much easier to use!
Thanks again for a great tool!
Michael T.
Michael Tuttle a.k.a. mictu
http://www.coroflot.com/fish317537
Show messages: All  1-6  7-12
